| | #1 |
| Rock Crawler Join Date: Mar 2008 Location: Arizona
| I thought I would share my Berg Build. I call it Stars and Bars. Kit-Berg ESC-Sidewinder Radio- JrX3s Servo- Jr DS8711 Chassis/Skid- Zero Shocks- Kit/full droop 70w/30w mixed oil and ACE hardware inner springs. Front axle battery plate- Custom by me Motors- 45t intergy Battery- Hyperion 4s Bottom links- Stock/bent Top links- Front kit bumpers/rear revo push rods Tires- Losi Claws Wheels- Axial 7oz lead each front 3oz each rear and Berg kit wheels (same weight with M2 Moabs) Dig- Rizzo/rear lock and 4WD Body- Losi Grapler painted by me ![]() ![]() ![]() Battery plate mount ![]() I went for a Low CG and high ground clearance ![]() The weight is low and forward with stiff shocks and limited articulation. This thing climbs like a homesick angle. I am very pleased with how it works. ![]() Here is where it gets it's name from. Last edited by Mic; 06-27-2008 at 03:02 PM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Dec 2007 Location: U S A
| Good looking body, wish I could paint like that |
| | #3 |
| Pebble Pounder Join Date: Dec 2007 Location: Torrance
| Did you clock the front axles? |
| | #4 |
| Thanks. Just some rattle cans and a little tape. Just a couple of degrees with longer upper links, it raises the motor just a little without messing up the front caster to much. |
| | #5 |
| After running it for some time. I am very satisfied with the battery plate setup and location. I may go with a smaller Maxamp 3s (or even the 4s) and mount it a little more laterally. I really like the 4s for the insane wheel speed but a little smaller battery may work just as well. The low forward weight distribution it is a great improvement over running the battery in the chassis |
| Thread Tools | |
| Display Modes | |
