Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: source for metric pinions ?
Old 06-30-2008, 11:16 AM   #1
Default source for metric pinions ?
i saw someone posted a source for the 48 pitch metric pinion's but i can't relocate the post
does anyone know where to get the metric pinion's ?
thanks
BoNuS LiNe is offline   Reply With Quote
Old 06-30-2008, 11:23 AM   #2
OCCUPY RCC!
dezfan's Avatar
I'm pretty sure Tower carries them.
Edit: they do.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFEA5&P=7
Are the Berg gears Metric? I thought I read somewhere they were standard?
dezfan is online now   Reply With Quote
Old 06-30-2008, 11:59 AM   #3
i have been told they are metric .
Old 06-30-2008, 12:14 PM   #4
varcor.org
swell searcher's Avatar
is there anyway to visual tell the difference?
swell searcher is online now   Reply With Quote
Old 06-30-2008, 12:23 PM   #5
The Berg gears are metric and you can get them at a main. I believe the other places that carry them will have them in the near future as well.
ncgoose is offline   Reply With Quote
Old 06-30-2008, 12:33 PM   #6
OCCUPY RCC!
dezfan's Avatar
Good to know, I need to get some ordered.
Old 06-30-2008, 01:26 PM   #7
They are metric, I used Tamiya as we have a pretty big Tamiya inventory, they call it 06 module.
I am running 14T on 55T motors and have comp wheelspeed to 35T 14/87 Axial tranny
Difuser is offline   Reply With Quote
Old 06-30-2008, 06:28 PM   #8
thanks
Anywhere in the rest of this planet...
Cordially.
People from the metric land.
Coligny is offline   Reply With Quote
Old 07-01-2008, 04:24 AM   #9
MWRCA'er
Mnster's Avatar
What are the majority of you people using for tooth count?
Mnster is offline   Reply With Quote
Old 07-01-2008, 10:06 AM   #10
Moderator
RXcrawler's Avatar
Stock pinion I think it's a 14 tooth.
RXcrawler is offline   Reply With Quote
Old 07-01-2008, 11:32 AM   #11
my stock pinions are 12 tooth
Old 07-03-2008, 04:14 AM   #12
MWRCA'er
Mnster's Avatar
Ordered 12's and a 13 tooth. I figured I'd try the different ratios in each axle I really like it's effect in my super.
Old 07-03-2008, 10:07 AM   #13
What kind of effect does it have?
v10king is offline   Reply With Quote
Old 07-03-2008, 02:21 PM   #14
MWRCA'er
Mnster's Avatar
Front pulls a little sooner then the rear. Really keeps the truck straight on climbs. Sort of like a FWD in snow. The rear at a higher ratio allows it to stall less then the front.
12 rear 13 front
Old 07-03-2008, 07:21 PM   #15
12 rear 13 front
Nice, that was always a no-no in the 1:1 world or shaft driven world but I guess since its independent it doesnt matter. I might try that I'll have to get an 11t rear.
Old 07-05-2008, 08:05 AM   #16
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I can confirm that they are not 48p "SAE" gears nor 0.5 Mod. There isn't proper mesh by my visual check. 0.6 Mod seems to be the best fit, and I have an assortment of 12-17t pinions on the way. I am also hitting up a pinion cutter to see if we can get 11 or 10t pinions made.
JohnRobHolmes is online now   Reply With Quote
Old 07-05-2008, 10:06 AM   #17
cato's Avatar
Robinson Racing .....makes metric pinions....give them a try
cato is offline   Reply With Quote
Old 07-05-2008, 10:43 AM   #18
I'm in for a set if you end up getting them made
Old 07-05-2008, 10:52 AM   #19
Robinson Racing doesn't answer phone calls or emails, but they do have a line of 0.6 Mod pinions in a steel alloy.
Old 07-05-2008, 10:53 AM   #20
sweet , im in for some 10 and 11 tooth pinions also
