08-02-2008, 10:52 PM | #1 |
| diesel's BlackJack-Ti berg.
i am finally building a berg based rig, using a double braced Ti blackjack chassis. frankyrizzo and i traded side plates so ive now got two braced sides and he's got two open sides. i had to cut my skid plate as my old link mounting locations wouldn't work with the berg gear cases. the front lower links are the same i ran on my TLT blackjack, the uppers are jato turnbuckles. on the rear we made new bent links with 4mm threaded rod and stainless steel tubing just like the fronts. the uppers are maxx turnbuckles i think. i had them laying around in a parts bin. specs so far; -BlackJack Ti chassis -enroute berg axles -integy 45t motors -rizzo dig -MX-3S radio system -sidewinder ESC (coming soon) -mayhem delrin berg bead locks (coming soon) -hitec 5645 servo (5995tg soon) -custom servo mount (in the works) -fubar rear lockouts -pro-line modified hammers -aces donuts hybrid memory foams |
08-02-2008, 10:56 PM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: Spokane
Lookin good!
08-02-2008, 10:57 PM | #3 |
Better late than never! |
08-02-2008, 11:37 PM | #4 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Welcome to the party I just finished mine 15 minutes ago. Heading out to Taylors Falls tomorrow for some testing. |
08-02-2008, 11:39 PM | #5 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
Looks slick |
08-02-2008, 11:49 PM | #6 |
thanks guys, at work on monday im gonna make my servo mount. just need one clamp thingy that goes around the tube. i bought them as an axle set so i didn't get servo mounts.
08-03-2008, 12:43 AM | #7 |
from the side pic you can see that i drilled new upper link holes. this makes it work much better than using the stock holes. the vertical seperation of the link mounts on the berg is too much for the stock holes on a blackjack. the suspension moves much more freely this way.
08-03-2008, 01:05 AM | #8 |
RCC Addict Join Date: Jun 2006 Location: Sin City
Looks good Scott I'm going to sell my scaler so I can get a set of axles
08-03-2008, 01:13 AM | #9 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
Those braced side peices are very needed. My second braced part is in order at FR.
08-03-2008, 01:13 AM | #10 |
i really like them i cant wait to get some drive time in one them... hopefully my mayhem wheels will be here about the same time as my sidewinder esc and ill be able to compete in this weekend's comp. actually mine are titanium, so even two open sides would be fine. rizzo is running two open Ti plates. |
08-03-2008, 01:19 AM | #11 | |
Looks good BTW Scott. | |
08-03-2008, 01:26 AM | #12 |
08-03-2008, 02:01 AM | #13 |
08-03-2008, 11:20 AM | #14 |
that makes 2...
08-03-2008, 12:49 PM | #15 |
Actually, I'm in for two sets.......
08-03-2008, 03:03 PM | #16 |
theres a thread over on sincityrcrc.com for titanium plates, anyone interested, get on there and put your name in for one!
08-04-2008, 12:11 AM | #17 |
Roger Dodger..... |
08-04-2008, 12:30 AM | #18 |
Need to see some finished pics. of your build if availiable. Im likin the super uber duber low stance thus far. |
08-04-2008, 09:28 PM | #19 |
update, got the steering hammered out. i cut up a template mount out of styrene and today i fabbed it out of aluminum at the shop. it uses the existing hole in the axle tube and one more than i drilled and tapped into the tube closer to the gearcase. it sets the servo pretty low, well protected. and definetly beefy enough. im not totally thrilled with the drag link/tie rod setup,might try double drag links to increase clearance and ditch the standup servo arm. |
08-04-2008, 09:41 PM | #20 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Running internal springs for droop? Or just heavy oil for droop, with the externals acting as a sprung combo? What are the specs of the suspension? I dig so far...............nice and low! |
