08-05-2008, 03:17 PM | #1 |
Newbie Join Date: Jun 2008 Location: Australia
| Lower turn motor up front
Had my Berg running for all about 4 hours.... Anyway the shop didnt have two identical motors, so I figured motors are cheap so I got a 45 and a 55 to get me running and stuck the 45 up front. I figured it wouldnt really make any difference and because I have never run it with two identical motors (the 4 hour thing) I really carnt tell. But anyway, I have been thinking... With a lower turn motor motor up front the amount of throttle you need on a crawling ledge to get the rear tyres to start to turn will be less. Meaning that when you got the front up on top of a ledge and they are turning over and the rears are stalled with the higher torque motor in the rear you will get less front wheelspeed before you can get the rear tyres to start to crawl. So it should make it crawl better cause you can crawl slower with less front tyre slippage... Got a 35 turn as well...I should throw that up there to see what happens...but with the 4 hour thing Ill probably leave it there for a while and just wheel it. But anyway..like I said...just thinking...may be worth while. Sam |
08-05-2008, 03:28 PM | #2 |
And remember, a lower turn motor needs more throttle input to drive at a given load. Or for a given throttle input it drives at a lower torque than a high turn motor. This is the effect I am believing is worthwhile. ...now it the front tyres are spinning relatively freely the high turn motor up front will actually make them spin faster meaning that if you are crawling with no tyre slip and the front breaks free the high turn motor up front will probably make the fronts spin faster...but because of the Generally when on "crawling" ledges with these things (4 hours expriencs in the dark up to 11.30pm at night) when you get front tyre slip on a ledge you play around with the front till you get it planted and them bring the rear up. On somehting when you carnt get the front planted you just snap the throttle a bit and I dont think any of this matters. Sam |
08-05-2008, 03:34 PM | #3 |
Rock Crawler Join Date: Mar 2007 Location: Man Cave!
I would think on a steep ledge or overhang, you would want the front to ingage first so as to not flip you over backwards. If the front grips and pulls first there is less chance of the rig ending up on it's lid.
08-05-2008, 03:51 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: stockton
08-05-2008, 04:34 PM | #5 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
You might want to do some reading in the clod section......the motor on axle is nothing new in crawling. There are years of research in there.
08-05-2008, 04:51 PM | #6 | |
It still does this exactly the same way, the front still pulls first..Its just that the torque bias is different. To look at the way my berg drives it behaves exactly the same way as a few clods that my friends have. It just that I think that running different turn motors may be an advantage cause on steep climbs teh rear has much more grip and can handle more torque...so why not give it more torque than the front with a high turn motor. May make it better overall? Sam | |
08-05-2008, 04:56 PM | #7 | |
I guess I should have alook at teh clod section. Sam | |
08-05-2008, 06:27 PM | #8 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
For those wanting different turns most use different sized pinions rather than different sized motors. Before going dual ESC I ran 6/7 pinions. |
08-05-2008, 06:33 PM | #9 |
I've got a 13T in the front, and a 12T in the rear of my Berg right now |
08-05-2008, 07:20 PM | #10 |
Ah! On the Berg I have 30 turn running 13/12 as well.
08-06-2008, 01:52 AM | #11 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
| Different turn motors in Clods isn't as common as different pinion gears front to rear. Usually with a higher tooth count in the front.
08-06-2008, 05:58 PM | #12 |
08-06-2008, 06:21 PM | #13 |
Rock Crawler Join Date: Sep 2006 Location: Esco.
08-06-2008, 06:49 PM | #14 | |
08-07-2008, 05:58 PM | #15 |
Newbie Join Date: Jul 2008 Location: Broomfield
I understand the physics, just don't know where to buy different pinions for my Berg axles. |
08-07-2008, 09:30 PM | #16 |
Here is where I picked mine up from, just make sure they are the metric 48pitch ones http://www3.towerhobbies.com/cgi-bin...&C=CLCRRP&P=SM |
08-07-2008, 10:16 PM | #17 | |
