08-26-2008, 08:37 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
| Anyone run droop with berg shocks?
Anyone run a droop setup with berg shocks. Any suggestions of internal springs to run with the berg shocks and where to get them?
08-26-2008, 09:01 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I run mine with Revo shocks. 25wt front and 40 rear. I run Century Springs C-620 internal springs. The Berg shocks are way too long. I recommend any 3.5" shocks. I really like the predictable way it drives. Last edited by FrankyRizzo; 08-26-2008 at 09:03 PM. |
08-26-2008, 09:42 PM | #3 |
Would the berg shocks work if I limit them and run a droop or would that limit the overall amount of travel that I would need and can only get with a shorter style shock? Am I thinking about this the correct way. In other words a shorter shock will have more travel than a longer shock that has limited?
08-26-2008, 09:44 PM | #4 |
Pebble Pounder Join Date: Sep 2005 Location: somewhere on earth
I am using the stock shocks with internal springs... around 40-45mm... so far no issue...
08-26-2008, 09:46 PM | #5 |
which springs are you running internally
08-27-2008, 05:17 AM | #6 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
I am running the stock shocks full droop on a KK Zero. I use internal springs from ACE hardware and 50w oil.(I also have some springs from TCS but have not used them yet) I use 3/4" of fuel line on the outside to adjust the ride hight to 3" . works great |
