08-29-2008, 04:57 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: Marysville
| My 2nd hand BERG
I bought this from a guy who "needed money". He had it set up pretty poorly. Even with my very noob crawling skills, it was apparent it needed some help. So, I did a LOT of reading, a LOT of asking questions, some practicing & tuning, then decided on a setup. And, here it is... Berg Axles Kamikaze Delrin Zero Chassis Custom Delrin Skid & Links - (Custom Delrin axle skids to be made) Traxxas GTR Shocks, 80% droop with internal springs Custom shock extensions, ride height 2.25" at rest 3.75" full extension Panther Cougar Tires on Mayhem Delrin wheels Bug Baja body - Pro-Line (to be Painted SOON) Mamba Max ESC with Castle BEC Simple Front DIG 3S 2500 Lipo 55T Integy Lathes - 13T front, 12T rear Hitec 5955TG - Lowered mount & reprog to 120 deg sweep Clocked Axles front & rear 6lb even RTR - 50/50 weight distribution Last edited by mchester; 09-01-2008 at 07:29 PM. |
08-29-2008, 04:59 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I may just have to color mine red in the middle. Lookin good! They work even better than they look though........
09-03-2008, 07:38 PM | #3 |
| 2nd installment
Finally with Mayhems and a finished body, more to come. Have a Bug almost ready and an S2000 in the wings. Nice and low. The extra body holes make it a little lighter... They were there from a previous mount. Last edited by mchester; 09-03-2008 at 07:42 PM. |
09-03-2008, 08:15 PM | #4 |
Rock Stacker Join Date: Aug 2008 Location: Austin
Nice, howsabout some naked shots? lol
09-03-2008, 08:22 PM | #5 |
| These weren't enough? My 2nd hand BERG |
09-03-2008, 11:26 PM | #6 |
Rock Crawler Join Date: May 2006 Location: Georgia
I really like the look |
09-04-2008, 02:17 PM | #7 |
09-12-2008, 12:01 AM | #8 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Looking pretty good! You sure you want to abuse that thing?:-P |
09-12-2008, 10:23 AM | #9 |
09-12-2008, 01:10 PM | #10 |
Newbie Join Date: Jul 2006 Location: Highland Village
Body looks cool slammed down that low, does the axle hit in the front at all?
09-12-2008, 01:18 PM | #11 |
| It makes light contact at extreme flex, but that's why I have the body mounted on only 2 central posts so it moves very easily up to an inch each way. Seems to work pretty well on the rocks so far, but I may trim the sides up a bit more to avoid dragging them so much. It doesn't hang up enough to stop momentum due to the body rocking side to side so easily, but it does drag a bit and will eventually get torn up on the edges...
09-13-2008, 01:16 AM | #12 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
lookin good. I like the LOW CG characteristic. Panthers are a compliment too. Mayhem pulled thru for you. Waiting on my order from Dan. |
09-21-2008, 08:22 PM | #13 | |
(but honey, I just need to melt your jewelry down for some wheel weights)... Right.... | |
09-22-2008, 10:09 AM | #14 |
Mayhem 7's with 7/16" galvanized steel rod, cut to 1/2" length, painted, then inserted into the holes in the wheels... On the back side, I used an inside snap ring to hold the slugs against the beadlock on the front side. This system seems to work just fine keeping the slugs in place and with no knuckle interference. This added about 3.5 ounces to each wheel with all 7 slugs in place. |
