09-03-2008, 07:37 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: Lagrange
| dig problem
I wired mine up the way the diagram below says too but when i plug my battery up the front wheels spin on their own...The back wheels do not spin and this is with the dx3r on and all setting too 0...I checked the wiring over and over and i dont see anything wrong..has anyone else had this problem?
09-03-2008, 09:27 PM | #2 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
Is this while using the throttle? Putting power past the ESC? If so maybe you fried a switch when you soldered it in :-(
09-03-2008, 10:14 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Disconnect the dig servo from the ESC. Doe the rig function normal? If you answered, "NO" then the problem may be that your radio isn't setup correctly. If the front wheels are turning, it should be receiving that info from the ESC. If you answersed, "YES" then your wiring isn't connected right. |
09-03-2008, 10:25 PM | #4 |
Do you have a pics of the your wiring set up? It would help as well. |
09-03-2008, 10:28 PM | #5 |
Newbie Join Date: Jul 2008 Location: united kingdom
| why
why have a dig on the front as well as the back, i have mine wired for the back only and it works great. would you have the front wired as well if you have rear wheel steering or do you have it with the dig anyway. what are the advantages. thanks we're all in the sh*t its only the depth that varies |
09-03-2008, 11:26 PM | #6 | |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Watch and be amazed!!! Kamikaze practicing. NO need to debate about the rules here guys. | |
09-03-2008, 11:28 PM | #7 |
This should be good for 3 or 4 pages of debate. |
09-03-2008, 11:31 PM | #8 |
09-03-2008, 11:36 PM | #9 | |
Hopefully by next year school will be done with and I can go! You guys stopping in Columbia on the way home? | |
09-03-2008, 11:48 PM | #10 |
09-04-2008, 12:21 AM | #11 |
I took the dig out and wired the motors up directly to the esc and it works now so I'm going to re-wire the dig switches tomorrow and maybe i can get it right this time... I suck at electrical stuff and soldering so this is a pain in my arse...
09-04-2008, 01:01 AM | #12 |
Quarry Creeper Join Date: May 2006 Location: Snake Run, IN
That was my diagram that you posted. I have wired 3 of these and have talked to several others that used it with no problems. When you redo it pay close attention to the NO/NC points on the switches. I would guess that this is where your problem is. Please post up when you find the problem and share. EDIT: I do not see any way that your truck should be running without you pulling the trigger. The outprut from the ESC should be 0 at this point and no matter what your problem the truck should not move. Last edited by pup; 09-04-2008 at 01:04 AM. |
09-04-2008, 01:09 AM | #13 | |
You will be amazed at the amount of times you will use it once it is there as an option. Last edited by pup; 09-04-2008 at 09:26 AM. | |
09-04-2008, 02:58 AM | #14 | |
Newbie Join Date: Jun 2008 Location: Australia
| Quote: You know when you do a rear burn you should start with the front tyres turned away direction you want to move the rear and then as you burn the rear turn the front tyres towards the direction you want the rear to move. So in that instance you wanted to burn the rear to the left. You should start with the front turned right. Then start the rears spinning and while they are spinning, slowely turn the front tyres from right to left...one slow contininous motion...which will force the rears also to the left. Once you reach full left lock, stop the rears from spinning, turn the front all the way to the right and repeat. Works in the 1:1 stuff anyway. On flat ground you can basically move the rear anywhere you want...if you got enough time. Fawkin cool line...I wouldnt call that a penality...in 1:1 straddles only happen when a tyre is off the ground. When all 4 are on the ground you either touch the cone or you dont...but you rules dont really read that way... Sam | |
09-04-2008, 10:57 AM | #15 |
Rock Stacker Join Date: Apr 2008 Location: FT, Wayne
he should have gotten 10 points for the gate straddle. usrcca rule #7.2.5.2 - example 2 if one wheel from the front axle and one wheel from the rear axle passes between two gate markers (vehicle straddles a gate) that gate is considered a cleared gate. This however will result in a Gate Marker Penalty of 10 points and a gate progress bonus is awarded. |
09-04-2008, 11:17 AM | #16 | |
Rock Crawler Join Date: May 2007 Location: Prescott
WORD | |
09-04-2008, 02:48 PM | #17 | |
If that was in any 1:1 rockcrawling competition all over the world there would be no penality. Then a straddle is only called after the vehicle clears the gate...and up to that point you can drive where ever you want and how ever you want and as long as you dont touch a marker you dont get called. So in that vid when he cleared the gate all tyres went through and he didnt touch touch anything. A proper defination of how to clear a gate would also clear up when vehicles drive through a gate and then reverses ......... Bah..Im rambling... Back to your regular programing... Sam | |
09-07-2008, 06:22 AM | #18 |
| dggin it
i just watched the vid and i am pretty amazed, that was quite something. think i'm gonna get another micro swith and sort the job...lol thanks we're all in the sh*t, it's only the depth that varies |
09-08-2008, 08:17 PM | #19 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Check your brushes, one could be hanging up. after rebuilding my motors I had one brush hanging up, causing the motor to not spin.
09-09-2008, 07:21 AM | #20 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
Just watched the video, and while I thought it was pretty cool, I wasn't amazed. Nice though.
