09-23-2008, 12:55 PM | #1 |
Rock Stacker Join Date: Dec 2007 Location: in the "D"
| berg help!
ok so I got my berg running last night n my 6 cell nihm pack lit up bright orange n smoked. I think I fried my ccbec ( green light not on). I'm running a rooster crawler. It also won't move unless I unplug my ccbec/servo from the reciever. also are these axles spose to be loud n whinny?
09-23-2008, 12:57 PM | #2 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
did you unplug red wire from speedo? call me will send ya number |
09-23-2008, 09:24 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: Yuma
09-23-2008, 09:53 PM | #4 |
Rock Crawler Join Date: May 2007 Location: Arnold
I bought the berg kit and used the gears that came with the kit and it is as quiet as a wisper.The gears are metric also.
09-23-2008, 10:12 PM | #5 | |
RCC Addict Join Date: Nov 2007 Location: BV
Putting some grease on the gears isn't a bad idea. Also I'd advise pulling all the screws out and putting locktite on them. And, as mentioned earlier the gears are metric, standard 48p pinions will not work for long. Check your gear mesh, that may also be the problem. My berg axles are whisper quiet. | |
09-23-2008, 10:15 PM | #6 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
How did you have the CC BEC wired in? Another member fried their BEC earlier this week with it wired directly to the servo. edit: About the loud n whinny part.....................did you figure out the difference between clocking the axles and clocking the motors as you posted a couple of days ago? |
09-24-2008, 12:38 AM | #7 |
Pebble Pounder Join Date: Jul 2008 Location: Australia
My berg axles are from the kit and i'm using the stock metric pinion and i lubed the gears and it's STILL LOUD AND WHINNY
09-24-2008, 05:30 AM | #8 |
09-24-2008, 05:53 AM | #9 |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
The kit I built mine from had lube in both gearcases from the factory. Stock pinions with the proper gear mesh should be quiet. As for the smoked battery, sounds like a dead short, somewhere....which may have affected you BEC...... |
09-24-2008, 07:02 AM | #10 |
Pebble Pounder Join Date: Aug 2008 Location: Marysville
09-24-2008, 02:47 PM | #11 |
as for the wiring i followed a diagram on here from someone. i did leave the red wire on the reciever plug of my esc. thats prolly my problem there. as for the loud axles, i bought the axle kit (no pionion supplied ) i did use standard 48 pitch gears. my mesh wasnt tight but wasnt too loose either. i put a little gear grease in there due to them looking dry. im goin to purchase gear jelly and see how that works. where can i get those metric 48 pitch gears for the berg??????? |
09-24-2008, 02:49 PM | #12 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Why don't you check the thread below this one?
09-27-2008, 02:55 AM | #13 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
I read somewhere on a thread here on RCC(a few weeks ago) that the loud whining sound eventually goes away with use. gears need to be broken in.( Thats what I heard) My truck got quieter over the past three months with the same pinion from when I first builted it.(IMO)
09-27-2008, 06:46 AM | #14 | |
The berg gears are 48 metric pitched, that why it so loud. TCS sells metric pinions http://www.tcscrawlers.com/Pinions-S...p-1-c-273.html | |
