10-09-2008, 10:48 PM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: Tyler, Texas
| Pariahs' Zero 4.0
Well I decided I should switch to Bergs for the competitive edge and the reliability and simplicity of electronic digs. The build took me two nights to complete which is nice. Too easy! Getting it on the rocks for the first time, I was shocked that it already easily outperformed my TLT comp rig that had countless hours in tuning and fabricating. Definitely see why people call them cheaters. As for mods, I ditched the rear stock stub shafts for the Axial stubs because I knew they were a weak point from what I've read. Up front I fabbed up some frankenstein cvd's using the stock berg inner shafts and MIP cvds for the scorpion axles. I've ran them hard for about six runs without any problems yet. Hopefully they'll hold up untill MIP makes a Berg specific application. Other than the OTA steering, the rest of the rig pretty much follows the norm for Berg/Zero builds. Excellent chassis and links bty Kamikaze Very slick stuff. I narrowed the chassis up a little more for the tight V-notches we get into around here in East Texas and still works great. The breakdown: Zero 4.0 Kamikaze Kustoms hc links Extreme RC Ti upper links modded 4.0 big bore shocks Losi springs - whites and yellows Tekin FXR 1320 3 cell lipos 35T Warriors on order Hitec 5955 Panther tires Vanquish Pro Comp Revolvers Nomadio React RC4WD scorpion knuckles Fubar lockouts on order Ti drag link on order from Rocksmith Body - Old reliable. Discontinued HPI baja bug body... Jackasses On to the pics |
10-10-2008, 06:48 AM | #2 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
Looks good
10-10-2008, 07:42 AM | #3 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Nice KK BERG...The front steering set-up is pretty rad. I just got some Berg axles in the mail last night! |
10-10-2008, 08:09 AM | #4 |
Pebble Pounder Join Date: Apr 2008 Location: Fort Wayne
Looks good dude. I'd be a little nervous about having the dig servo pointed straight up like that. If it works, go with it. Ben |
10-10-2008, 09:58 AM | #5 |
| Jeff has been selling that dig plate from the start and I have not heard of a servo being damaged at all. For the most part we are all running that setup.And for a while the ESC and reciver was up there to.There is a body over it.
10-10-2008, 10:03 AM | #6 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
10-10-2008, 11:02 AM | #7 |
Pebble Pounder Join Date: May 2008 Location: Tyler, Texas
Iv'e driven Pariah's rig, its discustingly capable, he dominated locally, when he had his shafty, he will be banned if he keeps the sh*t up good job Jim |
10-10-2008, 02:16 PM | #8 | |
Ben | |
10-10-2008, 02:28 PM | #9 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
| I don't know if he should be banned, ut he deffinetly should have a handycap from the start. Nice job Jim Now we will never catch you. Oh well I guess I won't be hustling you after all. |
10-10-2008, 02:30 PM | #10 |
Oh I almost forgot...................... YOU SUCK! |
10-10-2008, 04:17 PM | #11 |
Thanks for the kind words guys. Well for most of you anyway. Bigflex, I was planning on keeping this one a secret till the next comp but decided to let the cat out of the bag anyway. It'll still be funny to see the look on the others faces who don't know yet. Main reason I made the switch was because of the issues I was having with mechanical digs. Just not reliable enough for me in comps. I'd be glad to share what I've learned while building this rig with anyone who might be interested. I try to post some pics of how I got the cvds to work if you guys are curious about it. Thanks for looking, Pariah |
10-10-2008, 05:05 PM | #12 | |
10-10-2008, 06:59 PM | #13 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
You should definitely post up on how you did the cvd's. |
10-10-2008, 08:39 PM | #14 |
10-10-2008, 10:02 PM | #15 |
Pariah is leading right now, and if the rest of us don't step up the game I guess it will stay that way... that reminds me I need to get the standings posted up on the Texas board |
10-10-2008, 10:17 PM | #16 |
10-11-2008, 12:20 AM | #17 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
Nice steering mate ! I would be keen to see how you made your own CVDs.
10-11-2008, 01:17 AM | #18 |
| It's posted in the Texas section on the second page, It was bad luck night for everyone espcially me 2.2 Results 1.Pariah 31 2.Nova's Ark 41 3.Damon 66 4.Little NA 81 5.Rober97dodge 86 6.Dustin 94 7.BigFlex 105 8.jwalker 105 9.Littleflex 108 10.mexiCAN't 109 |
10-11-2008, 04:20 AM | #19 |
Quarry Creeper Join Date: Feb 2008 Location: Weddington
Post up the cvd mod... |
10-11-2008, 11:45 AM | #20 |
| It's pretty simple if you or someone you know has access to a welding rig. You're basically cutting and splicing the two shafts to the original inner axle shaft length. After cutting them to the correct length, spot weld the shafts back together then grind the welds back down smooth. Then I used a piece of 1/4'' steel brake line as a sleeve to add strength back to the axle shaft. The O.D. of the axle shaft is right at 3/16'' and the inner diameter of the brake line is 3/16 or just a hair larger. I had to tap/press the sleeve into place on the shaft so it's a really nice fit. You must put the bearing on before you weld it all back together! You will also want to have a spray bottle handy to immediately cool the axle and bearing assembly down or the bearing will be ruined. Once the sleeve is in place, spot weld it to the axle shaft on both sides then smooth your welds back down making sure there's no clearance issues when reinstalling it into the housing. Hope this helps. There is a link below of the completed cvd. If needed, I can go into greater detail and I will be building another set of these next week so I'll take pics of each step if needed. Thanks, Pariah [IMG][/IMG] Last edited by pariah; 10-11-2008 at 01:16 PM. |
