12-01-2008, 11:48 AM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| 2 ESC's vs Dig switch
Is there a difference between the two?....I know its probley all radio set up, but can you do the same dig function with 2 ESC's as with a dig switch? Sorry for the noob question, Berg's are just a new adventure for me!
12-01-2008, 12:07 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The 2 ESC's will have more options, since you could control each esc seperately. You'd need a 4pk or other 4 channel radio to work 2 ESC's perfectly. Dig switches only allow 4wd, Front dig and rear dig (level of true lock of motors varies on wiring). |
12-01-2008, 01:43 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: Yuma
I am not sure how well this works, but if I had 2 esc's I would have went with this punkrock rc |
12-01-2008, 01:50 PM | #4 |
Quarry Creeper Join Date: Jun 2005 Location: in the middle of the pacific ocean
two ESC will give you more control options, and you will be able to eliminate motor stall. But it will also be more expensive, weigh more, and take up more space then 2 micro switches and a micro servo.
12-01-2008, 02:17 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
The control options of two esc outweigh any weight gain. A 4 channel radio is a plus but not an absolute necessity. The DX3R does not give you the control options that a Futaba 3PK will. With the Futaba you can do front/rear dig, lead or trail on the rear motor. You can run the rear in reverse or use it with minimum throttle to act as a freewheel.
12-01-2008, 02:27 PM | #6 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
12-01-2008, 05:56 PM | #7 |
12-01-2008, 06:45 PM | #8 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
And that resistance will vary depending on motor too. Different number of turns and different magnet strengths will give you different amounts of drag with the motor shorted.
12-01-2008, 07:06 PM | #9 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
i tried that whole dig switch thing a couple times. and being used to a shafty with flip switch dig and no stall... i couldnt take it and just went with dual sidewinders on my berg build and never looked back. im using a dx7 with mixxed f/r on the left stick and steering on it also so its all on 1 control but i can flip a switch and have front/reardig/reverse etc by useing the 2nd stick. - tre |
12-01-2008, 10:21 PM | #10 | ||
By feeding the rear about half the power as the front it still propels the rig up hill without wanting to flip the rig over. I wouldn't trade it for anything! Plus I can't drive a stick radio very well and with this I don't ever have to! | ||
12-01-2008, 10:46 PM | #11 |
RCC Addict Join Date: Mar 2006 Location: Xxx
The "dig switch" option is just that . Its an option to use so your total cost is down. Its more savy to replace a $2.00 radio shack switch then it is to buy a mamba. But like Harley said, With the 2 esc option you have the ability to use either motor as a slave and minimize its rpm's. |
12-01-2008, 11:21 PM | #12 |
I run 2 FX-Rs on my clod (for now) 2.2. As Harley said, its unreal to be able to set 50% power to the rear and drive as if you were digging up, but with a little extra throttle can 'bump' the car up a notch without it going over backwards. But I'm using a React ;). Not only that, here is Aus we can run rear steer, so by reversing the rear ESC and turning front and rear wheels in different directions, I can turn like a bobcat on the spot! Its handy to have the extra functions, but is it worth the extra cash? I think, just barely. |
