12-02-2008, 10:46 PM | #1 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
| Aussie Berg
Thought I would show you guys my Aussie Berg since I have been getting ideas from this forum from the start. Specs: Diffs: Clocked and modified Bergs (thanks to MTHead) Chassis: TTS MXC (http://www.tinytuffstuff.com) Servos: Hitec 5955 (front and rear) Wheels: Mayhem Engineering Berg offset Comp rims Tyres: Initially Losi Claws. But I have some HB Rovers on order. Motors: Venom Crawler 55T ESC: Dual FXRs Radio: Nomadio React Body: Grappler Anyway, a picture tells a thousand words.............. I will update the thread when I get on the rocks. Thanks for looking. |
12-02-2008, 10:54 PM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: Japan
Looking good mate, how does the chassis perform...and more importantly when is Benno going to have the ready? ;)
12-02-2008, 11:14 PM | #3 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
Sweet looking rig Hey have you heard from skr8pn (jason)
12-02-2008, 11:19 PM | #4 |
12-02-2008, 11:21 PM | #5 |
12-02-2008, 11:31 PM | #6 |
12-05-2008, 05:32 AM | #7 |
Linc has been around and reprogrammed the radio. Front and rear digs (and a few Team secrets ) Only issue I have so far is that I jumped the gun buying the 3S Lipos. The ones I bought (2450mah) are slightly too big for the battery spot in the chassis. So I will have to sell these and buy a couple more. Still waiting on Rover tyres. The Losis will do until they arrive. I have to say, from running it around setting it up, it seems like it will be tough to top. Here are some pics. More to follow once I hit the rocks. |
12-05-2008, 06:43 AM | #8 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
looks great! I like the red lower links, makes it look badass, lol
12-05-2008, 08:58 PM | #9 |
DOOH!!! Join Date: Feb 2007 Location: AZ
| Looks sick Dan!! Gotta love the twin FXR setup, works sweet huh... So where did you get the React skin from, all custom and whatnot? Just glad to see that made it safely |
12-06-2008, 12:22 AM | #10 |
Newbie Join Date: Aug 2008 Location: Australia
| t
Not to bad where are your body mounts mate how low does the front motor sit?how long do u give it till u need to replace the motor?
12-06-2008, 05:33 AM | #11 | |
The wiring setup looks familiar, doesn't it ? The React skin is from Lee at www.rev-rc.com | |
12-07-2008, 04:28 AM | #12 |
Body is mounted and trimmed. May require some more trimming when the Rovers arrive. She is ready to hit the rocks. I have run it around the house to set it all up. Seems like everything works as it should. I will get out this week after work if I can and test it all out. If not, then this weekends comp will be it's shakeout run ! On to the pics (the last pics of it looking this pretty ) |
12-07-2008, 09:08 AM | #13 |
Front and rear dig and front and rear steer with a 12.5" wheelbase has got to be entertaining.
12-07-2008, 12:35 PM | #14 |
Sure is mate. Allows for a fair amount of control.
12-20-2008, 12:21 AM | #15 |
I went to my first comp with the new rig and I had constant difficulties with the car. It would stall out and stop running. Still managed 4th :-) But it turns out the 24kg servos were too much for the BEC in the FXRs (even though I'm running dual speedies). So, after a quick search around, I located an 8 Amp BEC. Big props to Wattsuprc, as I ordered it at 6pm and had it at 10am the next morning (Brisbane to Sydney). I read reviews for installing the BEC. It was all Chinese to me ! So Jonesy came over and installed it for me after a quick call to confirm connection of the BEC into the receiver. Also managed to squeeze the 2450mah 3S lipo into the chassis. So I have 3 cell grunt (great wheel speed even with the 55T Venom motors) and decent runtime. The end result is that my car now does what it should do. I look forward to the next comp with my fully operational Berg !! |
12-20-2008, 07:45 AM | #16 |
Pebble Pounder Join Date: Sep 2008 Location: lafayette
thats a very clean berg
12-20-2008, 07:58 AM | #17 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Nice rig If you don't mind could you let me know what your track width is? Thanks for any info. Later Farmer |
12-20-2008, 07:15 PM | #18 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
12-20-2008, 08:49 PM | #19 |
Thanks for the comments guys :-) XJ Farmer - Outside of Losis, measured at the bottom (full ready to run weight) it is 257mm (or 10 1/8"). |
12-21-2008, 07:30 AM | #20 |
Thanks man, I'm hoping to get a set of those. The Dirty Harry's are a little to wide for me. 10.5 is to much. Later Farmer |
