12-04-2008, 11:45 AM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
| Berg axleshafts
I bent both the long and short axleshafts in one of my Berg axles and our local hobby shops don't stock Berg parts. We have a comp in 2 days and online ordering takes longer than that to get to Canada. Does anyone know if there's anything that'll work as a replacement until I get the real ones? I can cut a shaft down and grind the notch into the end if I have to but I don't have access to any machines to narrow the shaft. Has anyone else here tried something like this with success? I'm debating trying to bend them back to straight but I'd like to leave that until a last resort. Any ideas would be appreciated, thanks. |
12-04-2008, 12:28 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Seams like bending them back is your best option to me.
12-04-2008, 12:53 PM | #3 | |
Rock Crawler Join Date: Aug 2007 Location: mesa az
12-04-2008, 12:56 PM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: phx
Do you think you could heat them up w/ a little mapp gas and roll then flat again? You could roll them on an anvil w/ another piece of metal while applying heat. Just as a last resort of course.
12-04-2008, 01:29 PM | #5 |
TEAM RCC Join Date: Jul 2006 Location: Novato
just run them bent
12-04-2008, 02:31 PM | #6 |
Rock Crawler Join Date: Jul 2007 Location: central PA
How did you bend them if ya dont mind me asking? That is a pretty thick axle shaft to make bend easy |
12-05-2008, 11:58 AM | #7 |
RCC Addict Join Date: Jul 2008 Location: Sin City
| We tried this with some axles before to braze in the dog pins on the ends, it burns the carbon out of the steel and makes them way more brittle, i shattered a bearing and had to dremel the outer bearing race out of the axle.
