12-06-2008, 06:50 PM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| Attn: Berg Owners
I am in the process of building my Berg. I need a new radio, what would be the best pick for my Berg with a 2 ESC set and a Dig switch setup? thanks for putting up with all the Noob question!
12-06-2008, 06:55 PM | #2 |
12-06-2008, 06:57 PM | #3 |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
you pretty much have endless possibilities with the dx6i and dual esc's if you can get used to driving a stick |
12-06-2008, 07:10 PM | #4 |
RCC Addict Join Date: Dec 2005 Location: Tucson
| DX6 try Ebay nicer than the DX6i or airtronics RDS8000 both sticks have springs for returning to center. DX do not. The only use i see with 2 esc and a dig switch is shorting the motor out for lock. other than that there is no use for dig switch with 2 esc. |
12-06-2008, 08:03 PM | #5 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| nomadio
Nomadio sensor!!!! We have a secret. |
12-06-2008, 08:11 PM | #6 |
well if youre running dual ESCs you dont need dig switches... and get a dx6.
12-06-2008, 08:19 PM | #7 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Dual stick - Spektrum DX6. Lots of possibilities for setup. Pistol grip - Nomadio React. Has 4 channels and the ability to assign any button to do what you want. - Spektrum DX3r. 3 channels, but very user friendly to setup. |
12-06-2008, 09:35 PM | #8 |
oops i ment with 2 ESC's or with a Dig setup!
12-06-2008, 09:39 PM | #9 |
RCC Addict Join Date: Jun 2004 Location: Little Rock, AR
I run two ESC's with semi free roll and dig using the gear switch. I have the same dig as a DX3R and independent axles.
12-06-2008, 09:43 PM | #10 |
is the Sensor the same programing wise as a React?
12-06-2008, 09:50 PM | #11 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
If you are considering stick radios, get a DX7. It blows away the DX5, DX6, & DX6i. The programming is so much easier and it has a built in 3 position switch. If you can afford it, it's the better transmitter. I started with the DX6 and moved up to the DX7 so I speak from experience. I will admit, stick radios are not for everyone, but if you can get use to it, it's got endless possibilities. |
12-06-2008, 11:51 PM | #12 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
One of the guys posted his set up for the Futaba 4PK. It's a pretty spendy radio but in my eye's it's totally worth it. I have tried the stick radio thing and for me it just wasn't there. I have also tried te DX3R and had some major glitching issues and it felt like crap in my hand. I have never had good luck with Spektrum anything though. Maybe it has something to do with my bloodflow in my body o something. My buddy ran the car with the CX3R in it (his radio, my car) and no glitching. I run it and it goes wild. And nothing changed, not even a flick of the on/off switch. |
12-06-2008, 11:58 PM | #13 |
When I first was building my berg I bought the DX6i. I tried it but couldn't get used to the stick driving especially when under the comp pressure. So I went to my DX3R using a switch style setup. Then I upgraded to the Futaba 4PK and went back to dual ESC's. I would never go back to a stick radio or the DX3R.
