02-27-2009, 06:01 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| How do I remove my knuckle bearings?
I'm swapping out my knuckles, but the bearings are in there pretty tight and I dont want to break something... Thanks. |
02-27-2009, 06:05 PM | #2 |
Quarry Creeper Join Date: Mar 2007 Location: Kerman, Ca
Mine were tight also. I used a small punch and lightly tap them out. You shouldn't damage anything as long as you don't get to crazy.
02-27-2009, 06:11 PM | #3 |
Rock Crawler Join Date: Jun 2008 Location: dublin
what knuckles are you going to ?
02-27-2009, 06:14 PM | #4 |
The Axial aluminum replacement ones.
02-27-2009, 06:14 PM | #5 |
02-27-2009, 06:15 PM | #6 |
02-27-2009, 06:17 PM | #7 |
02-27-2009, 06:21 PM | #8 |
02-27-2009, 06:24 PM | #9 | |
Thanks Dan! I test fit them once before, but I probably didn't tighten them down because I was still waiting for Jake to get Axial stub shafts in. And yeah, Bryan forgot to tell me I needed them, lol | |
02-27-2009, 06:47 PM | #10 |
hmm.. outer bearings came out easy. I'm kinda lost on the inners.
02-27-2009, 06:59 PM | #11 |
Team T1E/VP Driver Join Date: Feb 2008 Location: High Point
I used a stub shaft and pulled it out with a little leverage force... just push it to the side a little when pulling them out... worked like a champ...
02-27-2009, 07:06 PM | #12 |
02-27-2009, 07:28 PM | #13 |
Well I got all the bearings out except one, so I'm moving it to the rear axle. lol thanks guys. |
02-28-2009, 06:09 PM | #14 |
Rock Stacker Join Date: Aug 2007 Location: BC
i had hard time getting a few out as well when i was going to cut off my knuckle ends while doing some mods; a bit of heat with running the dremmel and the bearings fell out on their own. a bit of heat is the answer |
02-28-2009, 06:11 PM | #15 |
Just get new bearings, the stock Berg ones suck.
02-28-2009, 11:04 PM | #16 |
02-28-2009, 11:08 PM | #17 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
The stock bearings are just about the same quality as most bearings out there. Not sure why they would be described as "suck." They may not be top end, but good enough for crawling from my experience.
03-04-2009, 04:39 PM | #18 |
| I say they "suck" because I have a handful of the stock bearings that have gone out on me that have caused me to damage and have to replace gears and axles. Ever since I installed good quality bearings I have yet to have any failures. On one set of my Berg axles I had the knuckle bearings wear out in less than 10 packs. Hence the word suck.
03-04-2009, 07:19 PM | #19 |
Well, I will just throw my two cents out that I have yet to have a single problem with any of the stock bearings that came with my OCM kit. Hence why I would question why others would say they suck.
