03-09-2009, 01:10 PM | #1 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
| Berg tube diameter outside???
Anyone near one. Like to get something on order today at work. Berg is here only in spirit. :-P . Close is good enough. Is it 5/8 or 3/4" or. |
03-09-2009, 01:26 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Route One
outside diameter of what? the axles are 16mm o.d. |
03-09-2009, 02:07 PM | #3 |
yes sorry, axle tubes. so roughly 5/8". Thanks.
03-09-2009, 02:17 PM | #4 |
DOOH!!! Join Date: Feb 2007 Location: AZ
.627" give or take a few .000" due to plating... |
03-09-2009, 06:18 PM | #5 |
Quarry Creeper Join Date: May 2007 Location: home
When making my custom steering mounts i drilled a 5/8 hole in aluminum and cut it in half and it fits almost perfect to the size of the housing...
03-09-2009, 06:33 PM | #6 |
03-09-2009, 09:27 PM | #7 |
I took some 1" x 1/4" inch aluminum....Drilled a 5/8 hole then cut it in half at the center of the hole....drilled a 1/8" hole down the middle of that then drilled and tapped the axle tube...put a axial servo mount and wallahhhh....cheap steering mount...and that way i got to mount it at the exact height i wanted plus don't have those rings going below the stock axle to hang up like the stock steering kit... |
03-09-2009, 09:42 PM | #8 |
very nice I think I will have to try that one. did you have to take the axles completely apart? was it a pain? |
03-10-2009, 12:10 PM | #9 |
I did it when i had taken them apart to clock the axle....i would guess you could drill and tap it without taking apart but i would not recommend it...Taking the axle apart is simple and recommended if you have never done it so ya can loc-tite everything.
