03-24-2009, 08:58 PM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
| DTP's Kamikaze Zero 3.5
First, I'd like to thank my sponsors, RCP Crawlers, Montana Scale Designs, & Holmes Hobbies. Also, Thank you Jeff for hooking me up with three sweet chassis. Well, got the e-mail that my chassis shipped yesterday, so last night I tore down my previous comp rig. Took the shocks to work today to cut off the mounting tabs & drilled a hole in the top for a rod end. I was using Losi .6's which are 3.125678765578825". Obviously I need 3.5's for this, so with a rod end on it, it should be right there. I am also going to tap it for a 3mm screw, so hopefully it leaks less. When I got home I started wiring up the dig switches. Went with 4mm bullet connectors. Also used one of the micro servos from my DX6. Holmes Hobbies provied the manly switches. Going to work on the axles now................. |
03-24-2009, 09:31 PM | #2 |
Quarry Creeper Join Date: Jun 2008 Location: Honolulu
Will it be ready for sunday? I put some thread locker on the screw for the cap mod with no leaks what so ever |
03-24-2009, 09:36 PM | #3 | |
Are your's upside down or right side up? I think I might need them upside down for more clearance. Here's why. Got the front together for now. The VP knuckles looks like it will come close to the shock. I also need to grind the drive cup down tomorrow. | |
03-24-2009, 09:44 PM | #4 |
03-24-2009, 09:55 PM | #5 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
03-24-2009, 10:04 PM | #6 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
Are those the med. clearance links?
03-25-2009, 12:34 AM | #7 | ||
High clearance all around. | ||
03-25-2009, 12:36 AM | #8 |
Rear axle done. Fubar lockouts & KK axle plate is on, prolly put the battery there. |
03-25-2009, 12:38 AM | #9 |
Also got the wheels done. Straight dopeness. |
03-25-2009, 12:39 AM | #10 |
03-25-2009, 12:48 AM | #11 |
03-25-2009, 12:50 AM | #12 |
You'll have to wait and see!
03-25-2009, 12:51 AM | #13 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
Sexy rims, looks, "high powerd". Make sure the saftey is "on".(Can be deadly in competetition). Last edited by Da Hermit; 03-25-2009 at 12:58 AM. |
03-25-2009, 12:55 AM | #14 |
Pebble Pounder Join Date: Dec 2006 Location: da big island, HI
those new weights on the vp rims look sweet i might have to get some now are they heavier then the old ones?
03-25-2009, 07:36 AM | #15 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
yeah a little. a couple grams per slug.
03-27-2009, 02:57 PM | #16 |
Chassis came in the mail yesterday, but before I could get home & start, I had a little accident at work. While trying to remove a stripped screw, the screwdriver slipped I stabbed myself right in the meat of my palm. After spending 4 hours in the ER, mostly waiting & playing games on my Ipod, Got home I started one hand building. I already had the shocks finished, so I bolted everything up. I couldn't find any long 3mm button heads for the skid/lower links, so I just took the countersunks from the slingshot. All the LHS's are out of 3x30, but I think I know someone with some. On wed., while my hand was still good, I was able to grind down some axial stub shafts. I also had to put the bevel back on the inside of the cup. With these VP knuckles it is a must if you want any kind of steering as the knuckles mount closer to the C's. Looks like I got more throw too. Gotta go check the mailbox. |
03-27-2009, 03:20 PM | #17 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
you ground off the back of the axial stub shaft where the cup is? if so how much did you grind off thanks for the help |
03-27-2009, 03:23 PM | #18 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Its never going to work, you wont win one comp with a setup like that J/K Rig is looking like a champ. Wish my rig was comp ready. |
03-27-2009, 03:31 PM | #19 |
03-27-2009, 03:32 PM | #20 |
Got a package from Fubar Crawlers & Crawler Design Works...............Mmm Yummy.
