04-03-2009, 11:42 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Leesburg
| berg shock question Will stock berg shocks fit on the axial axels? If not, why not, and if so, is it a direct replacement or is there some type of mod to do so |
04-04-2009, 06:55 AM | #2 |
Rock Crawler Join Date: Sep 2007 Location: University City
| THe only problem i see is if you use the stock lower ball ends, they are fairly wide. But if you swapped them to the narrower axial ball ends, and ran some feul tubing in the top hole, you should be fine. i beleive they are about the same length.
04-04-2009, 08:20 AM | #3 |
Rock Crawler Join Date: Nov 2008 Location: kansas city
it really depends on what u want your ride hight at? i think stock axial are 120mm (correct me if im wrong) i like running 3.5" shocks (90mm) to help keep my cog lower. its all abou the tuning you want
