04-06-2009, 01:03 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: san diego
| First berg build
Building a berg with kk 4.0 chasis. Mid kk front links & high kkrear links. Running Losi shocks. Taxxas upper links. Sits to high at 3.4" & wheel base is only 11.25". Need some help. Any tricks
04-06-2009, 01:12 PM | #2 |
RCC Addict Join Date: Nov 2006 Location: southaven
pics would help.
04-06-2009, 06:37 PM | #3 |
What rod ends you using? Lay back your shocks? Reduce their travel? As said... pics would help.
04-06-2009, 07:55 PM | #4 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
Sounds Like your running the wrong rod ends. Make sure you use traxxas short revo rodends and your good to go. But 11.25!! that's 1 1.25" too short what went wrong? Did you cut the links at all? Let's see some pics and I will have a better point of veiw.
04-06-2009, 08:17 PM | #5 |
Well run shorter Shocks. Which will lower it and bring out the Wheelbase. How long are the shocks that are on it now? |
04-06-2009, 08:24 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
| You must have something weird going on with your rod ends. The upper link mounts are very high, at 3.4" ride height you should still be well over a 12" wb, there is very little wb change with this layout. Lets see some pictures and I'm sure the problem will be apparent.
04-06-2009, 08:30 PM | #7 |
Traxxas lrg rod ends. No I did not cut links. Lodi shock with traxxas small rod ends. Try to get some pictures up
04-06-2009, 08:32 PM | #8 |
Newbie Join Date: Oct 2007 Location: Rocklin
Maybe he means width @ 11.25 w/out berg offset wheels.
04-06-2009, 09:14 PM | #9 |
Pics Man!
04-06-2009, 10:09 PM | #10 |
| measred shocks. they were at 110mm. that was the problem. i had put a guide spacer on the shaft wich i removed & put the spring guide right on rod end wich made shock 95mm. height now is 2 7/8" & wheel base is 12.25". thanks guy for the input it helped alot
04-07-2009, 09:55 PM | #11 |
Berg newage axles traxxas upper links kk 4.0 kit banzai 45t motors mamba max dna rims rover white dots pro line oversize foams hitech 7955 servo castle bec hitech 65 dig dervo losi shocks ckrc bug body well heres the list of the rest of my stuff i'm building the berg with. |
04-11-2009, 09:48 PM | #12 |
the hitech 65 dig servo is only working good in one direction the other direction is glitchy. any idea's or did i just get a bad sero
04-11-2009, 11:30 PM | #13 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
what radio are you using?
04-12-2009, 08:48 AM | #14 |
dx3r
04-12-2009, 09:21 AM | #15 |
check the frame rate. I run mine in the middle, cannot remember which one it is.
04-12-2009, 11:00 AM | #16 |
yeah my frame rate was in the middle. had to switch the higher number for it to work
04-12-2009, 03:59 PM | #17 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
Mine did that too. I switched to 16.5ms frame rate on my DX3R and it went away.
