04-07-2009, 03:49 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: Oceanside
| Why run rear lockouts?
Why do Bergs need aftermarket 'rear lockouts' when they already come locked out on the rear axle? - Thanks
04-07-2009, 03:51 PM | #2 |
The stock lockouts are total tire grabbers. I shredded way too many tires on the stock lockouts. FUBAR lockouts are totally sweet. If I could use em up front and have no steering and still crawl, I would!
04-07-2009, 03:55 PM | #3 |
RCC Addict Join Date: Mar 2006 Location: Xxx
04-07-2009, 03:56 PM | #4 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
04-07-2009, 03:56 PM | #5 |
yep. the knuckles are too close to the tires, like EP said, they rip sidewalls. the fubars really are that cool... Last edited by dieselfuel; 04-07-2009 at 03:59 PM. |
04-07-2009, 04:02 PM | #6 |
Rock Stacker Join Date: Feb 2009 Location: Crofton
I like the ones from CKRC. They get rid of the c entirely and use a one piece shaft.
04-07-2009, 04:40 PM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: sacramento
04-07-2009, 04:53 PM | #8 |
the one piece shaft is cool, i'd like to try some ckrc ones...
04-07-2009, 05:01 PM | #9 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
| http://www.jpcustomrcs.atomicshops.c...89/6181037.htm These will be back in stock very soon. I have not seen a set of these worn out. Not to mention that it gives you an extra set of knuckles to use up front. |
04-07-2009, 05:23 PM | #10 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
04-07-2009, 08:20 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: home
With just a little modification the stock lock-out could be great...and free given you have the tools to do this.. I cut the steering arm down drilled a new hole closer then trimmed the lock-out rod up to fit over the C. And wallahhhhh |
