04-07-2009, 07:15 PM | #1 |
| Shane's Kamikaze Kustoms Zero ST Berg Thanks to all that helped out. I think I finally found a great setup for me. Several trails with wheel weight but I got it down now. Chassis is very predictable and flexes just enough. Steep uphills, sidehills, you name it's climbing it. Now if I can get the driver to be as good as the truck Kamikaze Kustoms Zero ST, Medium links, 3 1/8" belly clearance, 12 1/4" wb CDW OTA Steering, Vanquish Knuckles Losi .9's up front (some super thin shock oil i found laying around). 70mm links in rear Tekin Fx-R mounted on one side mounted post with small plate, Fx-R can be unvelcro'd and dig switches rotate up to have access to Nomadio receiver and work on chassis. HH Manly dig switches (electrical tape on dig switches to keep them from rubbing the chassis nuts/bolts), 11.1v lipo, 35t's 12 pinions, big fancy servo Mayhem 7's and chisels, nomadio react , ok pictures Last edited by Szczerba; 08-06-2009 at 07:52 AM. |
04-07-2009, 07:17 PM | #2 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
that is a great looking setup with some top notch parts |
04-08-2009, 09:01 AM | #3 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Can you get the Lipo in the belly? I have run both my ESC and a batt on the back axle and they have each taken good shots back there. Rig looks good though. |
04-08-2009, 07:00 PM | #4 |
| Thanks, Been a process of adding quality parts this truck. Thanks. Can't get the battery in the belly. Not enough room with the dig switches mounted the way they are and the Nomadio receiver. I've been running the battery on the back plate for several months now without a bad hit so far. |
04-08-2009, 07:09 PM | #5 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
| CoOL
Looks like your all done! Turned out good but that body post in the rear is gonna break for sure. Try to figure that out and it will be dialed.
04-08-2009, 08:57 PM | #6 |
nice looking rig. ive driven Havoc MOA trucks and i think the sprung/torsion thing is inda cool. i used to have my ESC on the rear axle and i beat the shit out of it. so mine is now safe between the chassis plates. |
04-09-2009, 06:20 AM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
its actually quite easy to protect your lipo or esc on the rear axle, all you need to do is cut a piece of lexan to fit, bend the back edge over to protect the back side of it and voila instant potection.
04-09-2009, 08:20 AM | #8 | ||
Good Idea. | ||
04-09-2009, 09:49 AM | #9 |
Pebble Pounder Join Date: Apr 2008 Location: Fort Wayne
How much does the rear flex? This looks like a cool setup. I run a rigid frame and have been contiplating making the rear rigid, leaving all the articulation to the front axle. It might just be crazy thinking, but I plan to try it for giggles. cool truck man. |
04-09-2009, 05:07 PM | #10 |
| Here are some rear flex shots. Rear is at full travel.
04-09-2009, 06:18 PM | #11 |
Newbie Join Date: Apr 2009 Location: Oroville
Im a noob, but I have been soaking up knowledge on this forum. Why put the battery in the back, I thought weight was prefered in the front rather then the back? Dig the digg set up by the way!!! |
04-09-2009, 06:46 PM | #12 |
Good question. These are my answers. These axles with the motors on them have plenty of weight to them. Steering servo weights about 2-2.5 oz. My batteries I run are 3-4 oz. Not alot of weight when compared to the axles with the motors on them. Only a few options (with MOA axles) to get the steering up and out of the way and usually no room for it up front (as you can with my over the axle steering) |
04-27-2009, 01:46 PM | #13 |
Finally placed at a comp. I am learning the in's and outs of the point scoring system to benefit my lack of skill right now. Got my first negative score (-5) on one course. The ST works great. Last edited by Szczerba; 12-10-2009 at 06:34 PM. |
04-01-2011, 09:23 AM | #14 |
sweet build bro
04-01-2011, 10:25 AM | #15 |
04-01-2011, 10:26 AM | #16 |
Wrong course direction, stop time, place you back to the previously cleared gate and 10 pts, bitch |
04-01-2011, 10:29 AM | #17 |
Actually, back in those days it was a DNF and 50pts. The rovers are on backwards too.
04-01-2011, 10:36 AM | #18 |
04-01-2011, 10:52 AM | #19 |
Quarry Creeper Join Date: Feb 2009 Location: clover, sc
And those axle tubes like omg. ( in my best valley girl voice) lmao
04-01-2011, 10:57 AM | #20 | |
Not to mention my battery-on-rear-axle setup . I still have this chassis hangin' on the wall. It was a good one. See what you started Ashton. | |
