View Poll Results: What have you broke the most on your berg | |||
Stub Axle | 20 | 29.41% | |
Inner Axle shaft | 6 | 8.82% | |
Inner axle Shaft Drive pin at dogbone | 34 | 50.00% | |
Gears | 4 | 5.88% | |
Bearings | 4 | 5.88% | |
Voters: 68. You may not vote on this poll |
06-19-2009, 04:06 PM | #1 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Whats the weakest part on your Berg
What is the weakest part on your Berg. What have you replaced the most? For me its the Berg stubs. The Axial hold up better, but I have broke them also. I have yet to break anything else. (Probably shouldn't have said that.) Last edited by The Violator; 06-19-2009 at 04:11 PM. |
06-19-2009, 04:09 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Inner axles. I have broken a few of them since I have had mine. But thats the only thing I have broken. This is if you have already replaced the outter shafts with Axials. |
06-19-2009, 04:09 PM | #3 |
| inners...to many of them. |
06-19-2009, 04:16 PM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Quite a few dogbone pins but I was running the CKRC knuckles which are far apart from the c's. I have not broken one since I have been running the Vanquish. So now the weakest part of my Berg is the driver. Last edited by dpdsurf; 06-19-2009 at 04:36 PM. |
06-19-2009, 05:16 PM | #5 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
i have broken 2 inner axle pins, a couple gears and stubs(stubs usually from a hefty toss, or as i like to think of it extreme testing) but i can't say that the poor things have been put to the test and most of the time survive.
06-19-2009, 05:39 PM | #6 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
I have been running Axial stubs since day one so I never broke any berg stubs. I have broke 5 longs axles though and two short side axles.
06-19-2009, 05:43 PM | #7 |
Gears, because of bearings. I have not had the shaft breaking problem like everyone else, maybe because mine are early units? My first set I broke a few but that was under ridiculous unnecessary strength testing, hey I wanted to know what they were made of!! |
06-19-2009, 08:12 PM | #8 |
Newbie Join Date: Jun 2008 Location: columbus
I put in the axial stubs before the first run and the only thing I have broke is the 12 tooth third gear in my front axle.
06-19-2009, 08:30 PM | #9 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
haven't managed to break anything (yet) I did have a crosspin slot on a plastic hex chew out, and the wheel nut tighten the wheel and hex so hard against the lockout it stalled out the rear motor and burnt it up. |
06-19-2009, 08:32 PM | #10 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
06-19-2009, 08:43 PM | #11 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
stubz and innerz.
06-19-2009, 08:48 PM | #12 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
its a tie between stubs (axial) and dogbone pins.
06-19-2009, 09:56 PM | #13 |
once the stock stubs are replaced with axial ones (as they should be) the inner dog bone pin is the weak link on mine.
06-19-2009, 10:50 PM | #14 |
DOOH!!! Join Date: Feb 2007 Location: AZ
I must have a light finger, nothing yet.. (knocks on wood) |
06-19-2009, 11:27 PM | #15 |
Quarry Creeper Join Date: Apr 2008 Location: st. george
So far my weakest point has been stub shafts. axial ones help that a bunch tho.
06-20-2009, 01:30 AM | #16 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
well they are strong but have broken small third gear and long axle dog bone.
06-20-2009, 07:35 AM | #17 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
No breakage, just bendage and wear-out |
06-20-2009, 09:17 AM | #18 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I haven't broken anything yet. Oh wait I am just now building one. |
06-22-2009, 09:40 PM | #19 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
06-22-2009, 10:02 PM | #20 |
So, it seems that the 2 weakest links are the outer stubs that can be helped by the way of the axial stubs, and the axle shafts at the pins. Can most of that be eliminated by limiting the steering. I have yet to break a pin, but I have my steering way limited. The pin never leaves the stub. But it takes dig to make most turns.
