Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
View Poll Results: What have you broke the most on your berg
Stub Axle 20 29.41%
Inner Axle shaft 6 8.82%
Inner axle Shaft Drive pin at dogbone 34 50.00%
Gears 4 5.88%
Bearings 4 5.88%
Voters: 68. You may not vote on this poll
Thread: Whats the weakest part on your Berg
Old 06-19-2009, 04:06 PM   #1
Default Whats the weakest part on your Berg
What is the weakest part on your Berg. What have you replaced the most?
For me its the Berg stubs. The Axial hold up better, but I have broke them also. I have yet to break anything else. (Probably shouldn't have said that.)
The Violator is offline   Reply With Quote
Old 06-19-2009, 04:09 PM   #2
Inner axles. I have broken a few of them since I have had mine. But thats the only thing I have broken.
This is if you have already replaced the outter shafts with Axials.
Rockcrawler is offline   Reply With Quote
Old 06-19-2009, 04:09 PM   #3
TEAM MODERATOR
Reflection's Avatar
inners...to many of them.
Reflection is offline   Reply With Quote
Old 06-19-2009, 04:16 PM   #4
Quite a few dogbone pins but I was running the CKRC knuckles which are far apart from the c's. I have not broken one since I have been running the Vanquish. So now the weakest part of my Berg is the driver.
dpdsurf is offline   Reply With Quote
Old 06-19-2009, 05:16 PM   #5
i have broken 2 inner axle pins, a couple gears and stubs(stubs usually from a hefty toss, or as i like to think of it extreme testing) but i can't say that the poor things have been put to the test and most of the time survive.
krawlfreak is offline   Reply With Quote
Old 06-19-2009, 05:39 PM   #6
I have been running Axial stubs since day one so I never broke any berg stubs. I have broke 5 longs axles though and two short side axles.
robert97dodge is offline   Reply With Quote
Old 06-19-2009, 05:43 PM   #7
666
MODERHATER™
666's Avatar
Gears, because of bearings. I have not had the shaft breaking problem like everyone else, maybe because mine are early units? My first set I broke a few but that was under ridiculous unnecessary strength testing, hey I wanted to know what they were made of!!
666 is offline   Reply With Quote
Old 06-19-2009, 08:12 PM   #8
I put in the axial stubs before the first run and the only thing I have broke is the 12 tooth third gear in my front axle.
crawlerbug is offline   Reply With Quote
Old 06-19-2009, 08:30 PM   #9
haven't managed to break anything (yet)
I did have a crosspin slot on a plastic hex chew out, and the wheel nut tighten the wheel and hex so hard against the lockout it stalled out the rear motor and burnt it up.
hairba11 is offline   Reply With Quote
Old 06-19-2009, 08:32 PM   #10
WOOPOOW!!
The dern driver
I would have to say the only thing ive done is bent my knuckles because the bolts backed out. If you dont thread lock all your bolts then you will break stuff
Colby is offline   Reply With Quote
Old 06-19-2009, 08:43 PM   #11
stubz and innerz.
ol' gravy leg is offline   Reply With Quote
Old 06-19-2009, 08:48 PM   #12
its a tie between stubs (axial) and dogbone pins.
slowngreen is offline   Reply With Quote
Old 06-19-2009, 09:56 PM   #13
once the stock stubs are replaced with axial ones (as they should be) the inner dog bone pin is the weak link on mine.
dieselfuel is offline   Reply With Quote
Old 06-19-2009, 10:50 PM   #14
DOOH!!!
I must have a light finger, nothing yet.. (knocks on wood)
MTHead is offline   Reply With Quote
Old 06-19-2009, 11:27 PM   #15
So far my weakest point has been stub shafts. axial ones help that a bunch tho.
webster420 is offline   Reply With Quote
Old 06-20-2009, 01:30 AM   #16
well they are strong but have broken small third gear and long axle dog bone.
tomer is offline   Reply With Quote
Old 06-20-2009, 07:35 AM   #17
No breakage, just bendage and wear-out
cato is offline   Reply With Quote
Old 06-20-2009, 09:17 AM   #18
I haven't broken anything yet. Oh wait I am just now building one.
bigflex is offline   Reply With Quote
Old 06-22-2009, 09:40 PM   #19
Nothing but bearing failure
Fishmaxx is offline   Reply With Quote
Old 06-22-2009, 10:02 PM   #20
So, it seems that the 2 weakest links are the outer stubs that can be helped by the way of the axial stubs, and the axle shafts at the pins. Can most of that be eliminated by limiting the steering. I have yet to break a pin, but I have my steering way limited. The pin never leaves the stub. But it takes dig to make most turns.
