04-15-2009, 06:47 PM | #1 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Anyone put Berg tubes on HR cases?
Ive been runnin my HR's for about a year now and its as dialed in as possible. I was thinking of switching to Berg tubes to help my scrub radius and have the wheels cover my C's a little better that on my HR's. I would just build a Berg but I need to run the HR gears anyway so I may as well keep the HR cases and slap on some Berg tubes..... If possible Anyone done it? |
04-15-2009, 07:30 PM | #2 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
hey The cases and tubes can be switched around. You will lose the slight clocking of the HR, because the clocking is in the tube. I have one set of HR axles with Berg tubes up front and a set of Berg axles with HR tubes on the back. You will need the longer shafts too, and you might as well get a Berg Spool, it is much stronger then the HR one. |
04-15-2009, 07:38 PM | #3 |
My HR's are already clocked so switching to the Berg tubes will change my "clocked" angle? I have the Berg spools in there already. Thanks |
04-16-2009, 06:33 AM | #4 |
hey If you put a Berg Tube on a HR case, it takes the 5 degree clocking out of the assembly. |
04-16-2009, 08:05 AM | #5 |
04-17-2009, 11:41 PM | #6 |
Newbie Join Date: Jun 2008 Location: Winnemucca
I have a set of berg axle tubs. I'll just give you if you want them |
04-18-2009, 01:51 AM | #7 |
have the HR MOA axles even been out for a year? not calling BS or anything, but really, has it been that long?
04-19-2009, 09:33 PM | #8 | |
Yeah now that you mention it I was running my Raptor's at Nationals last year so I guess it was just after Nats when I built my HR rig.. Seems like a year | |
04-20-2009, 11:03 PM | #9 |
I suppose you want titanium axles to |
04-21-2009, 10:19 AM | #10 |
04-21-2009, 03:59 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
04-21-2009, 09:05 PM | #12 |
