04-16-2009, 11:31 AM | #1 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
| Front dig and rear freewheel?
Right now my Berg is set up with f/r dig using microswitch. I hardly use rear dig but came across moments were I would have liked resr freewheel. Is there a way to wire up front dig and rear freewheel without using dual ESC's?
04-16-2009, 11:36 AM | #2 |
Do you have your switches wired up now so that it shorts the motor while in dig to lock it?
04-16-2009, 12:03 PM | #3 |
04-16-2009, 12:03 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I think you could wire the rear switch so it disconnects the rear motor instead or shorting it, but wouldn't you still have the resitance of the gears and motor?
04-16-2009, 12:19 PM | #5 |
| I guess if I could find a switch that opens the circuit when press it would be easy. Like I said I know I'd never gain true freewheel, drag from motor/gears, but cutting power instead of shorting would be more useful in some point I think.
04-16-2009, 12:25 PM | #6 |
I believe this would do it for you. Someone will have to correct me if I am wrong.
04-16-2009, 12:31 PM | #7 | |
So you would have two switches, both wired to the rear motor, one to short it for front dig, and one to disconnect it for rear "freewheel". I think you would keep one switch setup like you have it now, move the front motor wires to the ESC positive and negative, and your new switch could just be a simple 2 prong on/off switch of the same type wired to the positive wire of the rear motor after the dig switch. I think that might work. Last edited by BigB_117; 04-16-2009 at 12:48 PM. | |
04-16-2009, 12:51 PM | #8 |
Pebble Pounder Join Date: Sep 2008 Location: in line at the patent office
this is how i wired mine the back motor does not lock but still drags some with motor and gear reduction and the front will lock |
04-16-2009, 01:12 PM | #9 | |
04-16-2009, 01:16 PM | #10 |
I think you got boss. No go hook it up. |
04-16-2009, 01:28 PM | #11 |
04-16-2009, 01:29 PM | #12 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
make it where it pulls a brush partially off the comm and you might get decent freewheel
