04-18-2009, 09:34 AM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Texas
| High Clearance knuckles
What knuckles is everybody using on the front, VP or CKRC? Either one have an advantage? Are there other options, possibly better ones, out there? Thanks |
04-18-2009, 09:45 AM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: mt sterling
I hae a set of CKRC and they work great for my rig.
04-18-2009, 10:14 AM | #3 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Vanquish all the way. They are very strong, and as a company they stand behind their stuff 100%.
04-18-2009, 10:59 AM | #4 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
It doesnt get ANY better than Vanquish Products. |
04-18-2009, 11:16 AM | #5 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
I personally have use both VP and CKRC knuckles both are great. VP knuckles are very nice. The CKRC knuckles have a short steering arm which causes the servo throw to be less for full lock to full lock steering which I like.
04-18-2009, 11:17 AM | #6 |
RCC Addict Join Date: Nov 2006 Location: southaven
i like my stock ones |
04-18-2009, 11:22 AM | #7 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
VP's for me. |
04-18-2009, 12:05 PM | #8 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
I have both and they're both high quality parts. The CRC knuckles don't clear the Mayhem Eng. wheels I have (by a very small amount) so I'm running the VPs. One set of the VPs I got has more clearance on the bearings than I would like and both the VP & CRC knuckles have more bearing clearance than any of the stock knuckles that I've taken apart. The VPs are beautifully machined and finished, just a step above the CRC in the looks dept. I don't know if it's common but I had to clearance the knuckles because they were rubbing the ends of the Berg axle Cs. I chose to clearance the knuckles but you could do the axles Cs to achieve the same thing. Very minor.... Seeing as how they're Axial parts they have more "float" or clearance on the steering axis than the stock parts and I used the Axial "Flange Pipe" bushings Pn AX30450 until I machined up some of my own that reduced the clearance everywhere for a little less slop in the steering.
04-18-2009, 05:25 PM | #9 |
Pebble Pounder Join Date: Mar 2009 Location: san diego
| Berg
Wich knuckles clear dna rims the best with the berg offset
04-18-2009, 08:15 PM | #10 |
Pebble Pounder Join Date: Feb 2009 Location: Ft. Worth
04-19-2009, 01:53 AM | #11 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
VP just sent me a set. Now I need to send them money. |
04-19-2009, 07:34 AM | #12 |
Rock Stacker Join Date: Jul 2008 Location: The County Hell
someone post a link to the vanquish knuckles... |
04-20-2009, 06:28 AM | #14 |
Welp, sounds like VP was the way to go, they should be here in a few days! Thanks all!
04-22-2009, 01:05 PM | #15 | |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
The inside ring of the DNA Beadlocks will have to be countersunk. the screws hit the arm. Hope that helps | |
04-22-2009, 02:54 PM | #16 |
Cool thanks bro
04-23-2009, 06:52 AM | #17 |
Pebble Pounder Join Date: May 2008 Location: Cottage Grove
Do the vp knuckles clear with mayhem wheels
04-23-2009, 08:19 AM | #18 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
They clear berg offset sevens...no problem |
04-23-2009, 04:34 PM | #19 |
