04-22-2009, 07:53 AM | #1 |
Rock Stacker Join Date: Jul 2008 Location: The County Hell
| 55t Integy Vs?
Hey guys I am runing (2) Integy 55t motors on a Tekin FXr, I noticed a big downfall when I engaged front dig, there was not enough wheelspin to make a tight turn, what do you recommed should I go 45t or 35t? also maybe this is a dumb ? but would you ever want to put a lower turn up front i.e.(45t) and a (55t) in the back, or would that drag the ass end? pig |
04-22-2009, 08:04 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I am running handwound 45t motors and they are about perfect. But before them, I ran the el cheapo integy 45t motors and they had pretty good wheelspeed, but not nearly as smooth as the handwounds.
04-22-2009, 10:36 AM | #3 |
RCC Addict Join Date: Nov 2006 Location: southaven
45t stock 12t pinions on 11.1v |
04-22-2009, 10:42 AM | #4 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
11.1 volt is key! i run 55t stock pinion plenty of wheel speed, |
04-22-2009, 01:35 PM | #5 |
12tooth pinions and 35t cheap integy's on 11.1v with the Fx-R and elec digs. Plenty of wheelspeed. I just adjust the expontential throttle setting on my Nomadio and it takes away some of that rough startup. |
04-22-2009, 02:06 PM | #6 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
Holy Roller uses 55T Integy V11's with a mamba max 11.1V 3S lipo and has no problem at all. I am running 45T Holmes Hobbies handwounds with a mamba max and 11.1 3S lipos and holy cow I can not believe the amount of torque and power. |
04-22-2009, 04:29 PM | #7 |
Pebble Pounder Join Date: Oct 2006 Location: Ogden, Utah
55t Tekins 12t pinions FXR 11.1v 3s = Perfect wheel speed... |
