04-23-2009, 02:40 PM | #1 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| New to the Darkside - questions already.
Ok, I have made the switch to the Berglers. Ordered them from CKRC and they are the Newage. No big deal on the names I guess anymore. Heard that they are all the same. Anyway, I am already concerned about something. The axles do not operate smoothly at all. If I turn an axle on the front stub it will rotate about 280 degrees and then snag on something?! There is also a very noticeable gear noise coming from it. I tore it apart and I found that the gear that is furthest from the axles shafts (don't know what gear number, sorry) is wobbly. The shaft is fine, but the gear face is offset and wobbles?! I am not sure it is ok, but that is why I am asking. Same thing for the rear as well. I tore it apart and I can't find a single thing that owuld bind it up? Since I am new to Bergs I though that I would ask all of you. Any ideas would be appreciated. Jon |
04-23-2009, 02:45 PM | #2 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
At first they seem to do that from my experience with these axles. After tearing them down, lubing them up, and lock titing the screws I have never had a problem. I have put four together now without any issues. If you have any questions call or PM me.
04-23-2009, 03:34 PM | #3 |
no talent hack Join Date: Feb 2007 Location: Redwood City
they have a break in period. try to ignore the urges to fix them, and just run it
04-23-2009, 04:18 PM | #4 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
same with mine. lube em up run them and they will wear in.
04-23-2009, 04:30 PM | #5 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
mine did that too, just run them and they'll break in.
04-23-2009, 05:00 PM | #6 |
Quarry Creeper Join Date: Feb 2008 Location: Rhode Island
Good to know as I should be building mine sometime early next week! How is white lithium grease for everything? |
04-23-2009, 06:29 PM | #7 |
Pebble Pounder Join Date: Nov 2007 Location: Santa Ana*O.C.
04-24-2009, 01:02 AM | #8 |
Rock Crawler Join Date: Aug 2007 Location: mesa az
| run 'em and don't look back!!!!!!!!! |
04-24-2009, 01:20 AM | #9 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Agree'd. Ive probably seen 5 sets of new berg's infront of me. All had a tight spot. All taken apart, loctited, Greased. All are super quite with zero issues. Run it |
04-24-2009, 08:31 AM | #10 |
Ok, good to know guys, thank you. I was assuming that but just needed to know. I did forget to ask another thing though, the grease. It comes with machine grease I am thinking. so these need to be lubed. Doesn't that meant that the pinion on the motor will get greasy too?! Won't that get into the motor? I guess it really can't hurt but I want to be clear. And what do you all use for the grease? I am partial to white lithium but is there something better to use? Thanks all. |
04-24-2009, 08:44 AM | #11 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
cheater rig | |
04-24-2009, 08:51 AM | #12 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
I use white lithium in my berg, never had any issues with it. I do tear it down every few comps or so and re-grease it up though.. |
04-24-2009, 09:02 AM | #13 | |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
04-24-2009, 09:25 AM | #14 | |
It isn't cheating Joe. I think they look cool, that is it?! | |
04-24-2009, 06:01 PM | #15 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Be sure to clean and inspect your gears really well while you have everything apart to loctite it all. I found some metal slivers in the teeth of a couple gears in one axle that could caused some problems.
