04-25-2009, 08:43 PM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| Darkside Question???
I am going to come over to the darkside, but before I do I have a newbie question. What is better for a newbie to get started in this hobby with one of these vehicles? Is it better to get a kit or just buy parts and put the vehicle together with help from members of this forum? Here area a couple of kits I have looked at so far in my search http://www.ckrccrawlers.com/shop/ind...oducts_id=1919 http://www.ckrccrawlers.com/shop/ind...oducts_id=1537 http://www.tcscrawlers.com/On-Sale-1...p-p-16898.html I just need some general direction. I have read build thread on these vehicles and would appreciate some experienced help on which way to go for a newbie, |
04-25-2009, 09:30 PM | #2 |
Rock Crawler Join Date: Jun 2008 Location: dublin
none of those. i would buy a chassis that you like and buy a set of berg axles from whomever and start your build. a little more time and research, but it will be worth it in the long run and you'll have a better rig. jmo.
04-25-2009, 09:39 PM | #3 |
Pebble Pounder Join Date: Mar 2009 Location: san diego
buy th parts & build your own. read up on some berg builds & make your list.
04-26-2009, 01:06 AM | #4 | |
Is the Kamikaze 4.0 chassis a good berg chassis??? Last edited by BMFOTP; 04-26-2009 at 01:38 AM. Reason: added info | |
04-26-2009, 01:06 AM | #5 |
04-26-2009, 05:48 AM | #6 | |
Check out the T1E Rockshow. It's a bodiless chassis. That's what I run and it's great. The Kamikaze Chassis is top notch and an RCC favorite and I like the looks of CDW too. Basically... all the chassis made for MOA's are good for MOA's. Just stay away from the Berg Kit stuff. | |
04-26-2009, 11:58 AM | #7 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
I would wait a little bit longer to buy a Chassis |
04-26-2009, 12:17 PM | #8 |
04-27-2009, 12:03 PM | #9 | |
04-27-2009, 12:08 PM | #10 |
04-28-2009, 09:14 PM | #11 |
Rock Stacker Join Date: Apr 2009 Location: San Jose
I would just buy the Berg 2.2 kit in your initial post from CKRC. The price of the Berg axles alone will cost you a good portion of the price for the kit from CKRC. The kit includes shocks and wheels that you can use even if you build your own chassis, and will allow you to get started quickly and learn what you want. ~petev |
04-29-2009, 10:57 AM | #12 |
Rock Stacker Join Date: Jul 2008 Location: The County Hell
by far build your own, more than enough insight to a killer setup... I tried 3 chassis before I actually ran mine, then settled w/ an El Nino, now I just need to upgrade from a 2s to a 3s lipo...
04-29-2009, 11:28 AM | #13 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Build your own man...That way the end result will be exactly what you want it to be.Plus when you build your won rig from the ground up you will learn a lot more about it and how it all works,thus making tuning and such more of a second nature. So IMO I would look at the vendors section,find you a MOA style chassis that you like,buy some Berg or Bully axles and then start piecing it all together.You will be much happier with what you have in the end that way. |
04-29-2009, 12:35 PM | #14 | |
Winner: Kit MOA The last point is enough to make me want to get a kit MOA.:-( | |
04-29-2009, 12:37 PM | #15 |
| How much did the 3 chassis you tried before setting on the El Nino cost? What made you decide on the El Nino chassis? I have never heard of the El Nino chassis. Could you supply a hyperlink?
04-29-2009, 12:40 PM | #16 | |
04-29-2009, 01:44 PM | #17 |
stock newage chassis was a piece of dog schit, the SWX bender chassis was good but was too high, the El Nino chassis is made by Chaotic Crawler PM him on this site, a few of the local crawlers have it and I liked how it was setup, as far as the cost I bought the NEWAGE ENROUTE kit of which I used only a few parts, the SWX chasis was one I had purchased for an axial but never put it on, also the SWX width was too wide the El Nino uses 50mm spacers... I almost went w/ the RockShow from T1E it looks like a killer setup
04-29-2009, 01:51 PM | #18 |
Team T1E/VP Driver Join Date: Feb 2008 Location: High Point
| Hey BMFOTP.... we are having a comp not to far (couple hours drive) from you on the 9th, check out the details on NCRCC. You can check out several chassis there, plus there will be a ton of Rockshows there... NC is home to T1E |
04-29-2009, 03:22 PM | #19 |
Quarry Creeper Join Date: Feb 2008 Location: 36 N / 76 W
Cant go wrong w/ the Rockshow. Been running mine for a couple of months now and have done well in comps, the only thing holding her back is the driver. You won't find a nicer bunch of guy's either. The only people here that will flame you are jacka@@'s anyway and are thankfully outnumbered. |
04-29-2009, 04:54 PM | #20 | |
