04-27-2009, 10:09 PM | #1 |
Newbie Join Date: Jan 2009 Location: Canada
| Front wheel play, is this common?
Has anyone else had problems with play in the the front wheels? I can wiggle the front wheels pretty bad! I think it might be coming from the those little gold bushings in the steering hub arms, or mabey from the bearings in the c-hub. Is there a easy fix for this that could save me some messing around time?
04-27-2009, 10:13 PM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: Ft. Worth
Mine has it as well....I dont see it as a problem so I havent spent too much time messing with it....Ill watch this thread though and if something good comes up ill use it |
04-27-2009, 10:18 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The stock bearings do cause some play. Also the brass sleeves do where out over time. |
04-28-2009, 04:33 AM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: 36 N / 76 W
I switched out the brass bushings for a set of Axial steel bushings ( from the scorpion kit) . You have to file them down a bit since they are taller but they eliminate the slop and wont wear nearly as badly.
04-29-2009, 12:44 AM | #5 |
the axial ones are steel huh? hmm... im on my second set of berg bushings and theyre starting to get sloppy again.
04-29-2009, 05:06 AM | #6 |
04-29-2009, 06:28 AM | #7 |
Also HPI makes the same thing as the Axials...I believe they are cheaper by a few pennies. I might go that route...not looking forward to cutting them down though. |
04-29-2009, 10:08 AM | #8 |
cutting them down shouldn't be too big a deal. but out the dremel and take out a little bit at a time til they're right.
04-29-2009, 11:48 AM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
Take the bushings out and throw them away, than insert the knuckle screws left over from your TLT kit and enjoy slop free knuckles. |
04-30-2009, 10:15 AM | #10 |
Replace the bearings too. I notice play in mine again (already running Axial bushings) and found the stock bearings were blown. Just a good preventitve measure. |
05-04-2009, 07:10 PM | #11 |
05-04-2009, 07:13 PM | #12 |
05-04-2009, 07:29 PM | #13 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
05-04-2009, 07:32 PM | #14 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
1st signs of getting old you guys, you still have TLT parts laying around. I got about 7 or 8 of those boxes stacked up on a shelf.
05-04-2009, 07:46 PM | #15 |
05-04-2009, 09:58 PM | #16 | ||
