05-05-2009, 07:30 PM | #1 |
Newbie Join Date: Apr 2009 Location: Southern
| 2.2 kit
Put the kit together every thing is stock. Wanting to make the links a bit longer to raise the axles up some. i have the bent links on. Is there any benefit of keeping the bent links or just get new longer links. How much longer would i need to get the links to raise the axles? The links i have are 50mm (upper) and 100mm (lower).
05-05-2009, 08:36 PM | #2 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
What do you mean "raise the axle"? You talking rotating the axle so the motors is up a little higher??
05-05-2009, 08:39 PM | #3 |
Rock Stacker Join Date: Apr 2009 Location: california
clock em
05-05-2009, 09:25 PM | #4 |
yes
05-05-2009, 09:41 PM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: Rhode Island
You dont want to clock the front with links, as you will just be steering into the ground. You can clock the rear with 70MM links and it comes out perfect. The link is 70MM plus whatever the rod ends add.. Front has to be re-drilled and re-tapped for you to clock it. Im most likely going to leave the front of mine alone, as Its not really much of a problem. |
05-05-2009, 09:48 PM | #6 |
thanks
05-06-2009, 08:16 AM | #7 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
I left the front of mine alone to keep weight down low. Use links to rotate the rear to your liking.
