05-20-2009, 09:45 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Route One
| the FULCRUM moa Chassis / Wilberforce rebuild
This is my new chassis......the "FULCRUM" Custom upper 1/4" Delrin links M3 studs & Traxxas 3mm ends (not sure if they will hold up - kinda flexy) Downtown 3/8" Lower links M4 studs & Revo ends Revo shocks - full droop I will rebuild Wilberforce using most of my old parts and dig assembly. Electronics list goes.... Tekin FXR Castle BEC Airtronics 423oz steering servo Hitec HS-65 Mighty Feather dig servo 25 amp dig switches (no issues after atleast 1 full month of testing) DX3R Radio system Deans 12g wire & connectors Venom 50t motors |
05-20-2009, 02:19 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Looks good... Especially those links |
05-20-2009, 02:31 PM | #3 |
Rock Stacker Join Date: Apr 2009 Location: st.george
looks good need more pics
05-20-2009, 04:58 PM | #4 |
thanks guys I couldnt make it into the woods for a real test but it did well in my backyard....I ran a pack through with no issues. I getting the impression its going to sidehill ok. |
05-20-2009, 07:58 PM | #5 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
I like the looks of it. I like how you can stand the shocks up more vertical. What weight oil and what internal springs are you using on the Revo shocks? |
05-22-2009, 07:05 AM | #6 | |
I tried a bunch of different shock locations on prior setups and I found that when the shocks are really laid out (more flat than upright) my suspension is less sensitive and almost require more weight in the wheels to hold the rig down for the suspension to work. (I think thats the reason... works for me) Springs... I took my shock (body/damper & shaft) to the hardware store and tried a different springs for size and tension etc. just working the shock with my fingers untill I found a few that felt ok; then I tried them on the rig till I found a set that felt good to me. apprx. $0.75 cents each. Oil Weight... I tried 30wt but it was still tooo slow so I drilled the holes out in the shock damper one at a time untill I got the kinds of movement (rebound speed) I liked. Maybe lighter weight oil would do the same thing but I had 30 wt on hand. works good. 3" ground clearance and 4 7/8" max frame height = ok balance / sidehilling i think | |
05-22-2009, 06:26 PM | #7 |
Rock Stacker Join Date: Apr 2009 Location: california
nice renthal stickers! im a rider as well |
05-23-2009, 01:33 PM | #8 |
sweet I just wish I had more time for riding.... this RC addiction is killing me I took the Fulcrum to one of my "test spots" last evening and I hit some normally tough lines first & second shot. I think this one is gonna be hated |
