05-23-2009, 08:41 PM | #1 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
| Kami 3.5 or 4.0 question
What is the difference between the Kamikaze 3.5 and 4.0. I know one says to use 3.5" shocks and one is 4" shocks. Can you use 4" shocks on the 3.5 and just limit them?
05-24-2009, 05:43 AM | #2 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
05-24-2009, 07:55 AM | #3 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
I am also considering a kami frame
05-24-2009, 09:40 AM | #4 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
You can use 4 inch shocks with the 3.5. Depending on the ride height you want you may have to limit the shocks a lot and lay them down. If you are going to mod your shock caps I would strongly recomend going with the 4.0. The best setup I have watched work lately is the 4.0 with a 90mm shock. That is if you like a nice low setup. |
05-24-2009, 10:21 AM | #5 |
Rock Stacker Join Date: Oct 2008 Location: Oceanside
| You SHOULD use 4" shocks on the 4.0. If you limit the shocks on the 3.5 you will also have to use heavier oil and springs. The more laid out the shocks are the less the springs and oil affect articulation in both overall amount and resistance. In other words laid out shocks, even when limited, may allow for too much and too easy articulation...
05-24-2009, 02:10 PM | #6 | |
Please share your wisdom with us. | |
05-24-2009, 02:16 PM | #7 |
05-24-2009, 02:19 PM | #8 |
| Yeah Joe! Why!? |
05-24-2009, 02:36 PM | #9 | |
Well lets try this on for size. I may know a little about it.The 4.0 was designed for me In no way is the 4.0 just for the use with a 4 inch shock. As a matter of fact Jeff (Kamikaze) is running 90mm on his 4.0 If you run the 4.0 with a 90mm unmodded shock you get a very nice 2 5/8 GC if you use the shock mounting hole at the end of the chassis. A 90mm shock with a modded cap would put it around 3inches about the same as a unmodded 4 inch shock. Then a 4 inch shock with a modded cap requires you to limit about 3/16 of a inch and lay the shock back a hole or two for the same GC. Sounds like the 4.0 is pretty versatile to me. | |
05-24-2009, 09:02 PM | #10 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
| whoa whoa whoa
come on guys, Leave him alone. |
05-24-2009, 09:12 PM | #11 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I run the traxxas big bores that are 4" shocks with the 3.5 chassis.....I have 2 of them as a matter of fact. |
05-25-2009, 03:00 AM | #12 |
Thanks Guys for the information. I was really just worried about having to buy another pair of shocks especially if I did not need to. Didn't mean it to turn into a slug fest. I appreciate everyones info. |
05-26-2009, 10:24 AM | #13 |
Newbie Join Date: Sep 2008 Location: Hicktown
I run slightly limited 4" shocks on my 3.5 and love it. Adjust your shocks, oil, limiters, etc to fit your type of terrain and drving style. Some people like more GC than others and vice versa. Also what works in Ky or Tn probably won't be the hot set-up on the west coast, or the northeast, etc etc.
05-26-2009, 11:08 AM | #14 |
Pebble Pounder Join Date: Nov 2008 Location: Mission,BC
I'm running Losi 90's on my 3.5 with great success
05-26-2009, 04:44 PM | #15 | |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
06-01-2009, 06:04 PM | #16 | |
06-01-2009, 06:56 PM | #17 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Thats what the 4 cell and the 30 turn motors are for....... |
06-01-2009, 07:15 PM | #18 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
Either one is a sweet chassis. Plus Kamikaze's warranty rocks. I'm running the 3.5 with limited losi shocks.
06-01-2009, 08:33 PM | #19 |
