05-26-2009, 07:54 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: buford ga
| berg servo mount
how do you mount you servo on your berg truck
05-26-2009, 08:22 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Can do it using the stock lower, upper clamp and servo plate. can find them available separately on ckrc. Not sure on other ways, have been messing with my own way thats being a pain.
05-26-2009, 09:14 PM | #3 |
Quarry Creeper Join Date: Mar 2008 Location: san pancho, ca
one vote for the simplicity of vertical servo mounting bent the bracket out of aluminum for the top, and utilized one of the berg bolts for the bottom. |
05-26-2009, 09:26 PM | #4 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Keith, i told you half a dozen times you can have my old servo mount, I will even install it for you since i built it and only I know how to put it on |
05-26-2009, 09:45 PM | #5 | |
...couldnt resist... | |
05-26-2009, 09:51 PM | #6 |
Ouch Man that servo mount worked awesome for me.. got me a top 10 finish with a shitty servo..
05-27-2009, 05:45 AM | #7 |
05-27-2009, 06:49 AM | #8 |
05-27-2009, 08:24 AM | #9 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| Stock servo mount from CKRC Spaced up a little |
05-27-2009, 10:04 AM | #10 |
Rock Crawler Join Date: Aug 2007 Location: Atlanta
05-27-2009, 10:55 AM | #11 |
woww.. no you dont have to pay me for it, a wise person who helped me out once said that someone had helped them out when they were starting, so why not pass on the kindness?
05-27-2009, 05:36 PM | #12 |
05-27-2009, 05:45 PM | #13 |
Heres mine. |
05-27-2009, 07:11 PM | #14 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
Hey 666 ~ not to jack rccrawlerboy' here, but No problems with the Cap smashed on your MM?, I love your VP/homemadeBTA btw! gotta sit down and mock something like that up. . .
05-27-2009, 09:26 PM | #15 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
I'll agree with the devil on this one, make a mount to slam the servo on the axle as much as possible. I'm a big believer in keep weight low, no matter what it is, it all adds up. Mine is similar to 666's, (should be I pretty much copied his) my servo mount is just a piece of 1/4" delrin plate cut to fit. |
05-27-2009, 09:27 PM | #16 | |
No problems, both my front and rear caps are smashed up pretty bad, one is just hanging there... Thanks, I give the most credit for the design to tmyjeeper, he got my mind thinking!! | |
05-27-2009, 09:31 PM | #17 |
05-27-2009, 09:57 PM | #18 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
05-27-2009, 10:22 PM | #19 |
Both of us used solid aluminum rod, he's using 3/8" and I used some 5/16". Normally they will just sit on the link but when you are at full lock it rubs the tire just a tad and it'll move. If you get the angle right it doesn't hit bad at all. Took me probably 3-4 tries before I got it where I was happy.
06-07-2009, 08:12 PM | #20 |
Can you get the rod at like home depot or something like that?
