06-02-2009, 09:31 AM | #1 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
| Lockouts...
I can't seem to find anyone that has lock outs in stock for berg axles. anyone know where I can get a set?
06-02-2009, 09:38 AM | #2 |
06-02-2009, 09:46 AM | #3 |
Both out of stock :-(
06-02-2009, 06:55 PM | #4 |
Rock Stacker Join Date: Oct 2008 Location: Oceanside
| Yep, I had the same problem trying to get some lockouts...In the mean time I found a post on here from a guy who modified the stock lockouts to get them out of the way of the tires. I can't find his original post so I took a photo of my own handiwork. You need a 3mm drill and tap set and a couple of files. You don't need any parts. You just change the angle of the existing lockout by drilling a new hole closer to the axle and then you have to file a notch on the bottom of the lockout to clear the raised axle carrier mounts... Hold the axle carrier straight and position the inside of the lockout so that it is touching radius of the axle carrier. use a pen or some sort of marker to locate the place on the arm where you are going to drill and tap the new hole....That's about all there is to it...Works on stock Berg wheels as well as Mayhems. You would need to file a flat on the place where the screw goes into the arm to lower the outboard screw a bit for Vanquish Revolver wheels...Naturally, when you get it all to your satisfaction, cut the steering arm off short. A lot of work to save $24 but at the time there was no alternative other than CKRC's solid axle modification lockouts which required as much or more fabrication and cost $45 and leaves you with only one source for axles... Last edited by stevehof; 06-02-2009 at 09:15 PM. Reason: clarification |
06-02-2009, 09:13 PM | #5 |
Newbie Join Date: Apr 2009 Location: epsom
jp customs makes some nice ones http://www.jpcustomrcs.atomicshops.c...89/6181037.htm |
06-03-2009, 12:10 AM | #6 | |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
06-06-2009, 05:26 AM | #7 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
Any word on any in stock anywhere? |
06-06-2009, 05:36 AM | #8 |
As soon as I get back from Vacation. I will start another Batch of Lock-Outs.
06-06-2009, 06:01 AM | #9 |
06-13-2009, 01:24 AM | #10 |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
06-13-2009, 02:20 AM | #11 |
| If you or anyone else for that matter what a set from the next batch.. Just E-mail me with your RCC Screen name telling me you want a set. I will print that E-Mail out and save it. When I get them in. I will E-Mail everyone that did and let you guys know first thing.
06-24-2009, 07:38 AM | #12 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
How long til these are back in stock?
06-24-2009, 09:18 AM | #13 | |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
06-24-2009, 10:18 AM | #14 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
