On the Mahems site I see:
| Ordering Information To place an order, email us at: mayhem_eng@yahoo.com Standard 2.2 Beadlocks from Mayhem Engineering $95.00/set + $10.00 shipping with in the USA A set is any 4 rims, either offset, with any 4 front rings and 4 traditional back rings, any anodized color combination – your choice (Mix & Match or all the same) hardware included. (Traditional ME-2008-8 back rings and stainless steal hardware are standard unless otherwise stated.) Additional rings $30.00 / 4 rings $45.00 / 8 rings Engraving $20.00 (within reason). Engraving on Competition Rings only. We offer two different offsets in our standard 2.2 style rims. 1st Offset - .443 (11.25mm) this is a negative offset, meaning that the bottom of the hex is as close to the hub side as possible. (see Diagram A) This offset offers a wider track width. Original offset – Wide. 2nd Offset – Our latest design - This offset is .147 (3.7mm) this is also a negative offset. This offset will bring your wheels closer to the frame, this offers a narrower track width of approximately 10 ¼”. New offset – Narrow. We offer both the Wide and Narrow offsets in all of our wheel designs: 2.2 Mayhem “Spider Wide” ME-1001-W 2.2 Mayhem “Spider Narrow” ME-1001-N 2.2 Mayhem “7 Wide” ME-1002-W 2.2 Mayhem “7 Narrow” ME-1002-N 2.2 Mayhem “Phatty Wide” ME-1003-W 2.2 Mayhem “Phatty Narrow” ME-1003-N We have nine ring styles: 2.2 Mayhem “Grinder” ME - 2001 2.2 Mayhem “Custom” ME – 2002 (Front or Back Ring) 2.2 Mayhem “5 Point” ME - 2003 2.2 Mayhem “Competition 8” ME – 2004-8 (can be engraved for an add’l fee) 2.2 Mayhem “Competition 16” ME – 2004-16 (can be engraved for an add’l fee) 2.2 Mayhem “Nuke” ME - 2005 2.2 Mayhem “Nuke Plus” ME - 2006 2.2 Mayhem “Nuke Round” ME - 2007 2.2 Mayhem “Traditional” ME – 2008-8 (Front or Back Ring) 2.2 Mayhem “Traditional” ME – 2008-16 (Front or Back Ring) We offer five anodize colors plus Machine Finish (aluminum) Blue Red Gold Black Violet (special order) Green (special order) Diagram A Competition Double Phatty $130.00 shipped within the USA Part Number ME-1004-Comp (specify aluminum or Delrin) Rims available in Aluminum or Delrin The benefits of this design: Need only remove outside locking ring to adjust weight No need to remove the tire, saving time Adjust weight by adding or subtracting 9/16" ball bearings or stationary weights (stationary weights not provided) Just about any type of wheel weights (other than bearings) can be used Ball bearings will always stay at the bottom of the wheel to keep center of gravity at its lowest point Largest ball bearing 9/16" or smaller can be used The key to this design using any type of ball bearings is to KEEP them below center line of the wheel; if above center line it will not work as intended. If you are above center line the bearings have a tendency to flop over the top and lose the benefit of keeping the center of gravity at its lowest point This design doesn't add a lot of weight, but what weight is there keeps the center of gravity at its most useful point (low in the wheel) A Set Includes: Four (4) Mayhem 2.2 Competition Double Phatty Rims – Machine Finish or Delrin Four (4) Traditional rings - your choice of color (red, blue, gold, black or machine finish, violet and green are special order) Four (4) Competition 16 Rings - your choice of color (red, blue, gold, black or machine finish) - your choice of 8 or 16 mounting holes Sixteen (16) 9/16" dia. steel ball bearings 128 stainless steel button head screws Plus engraving (within reason) on any anodized color (machine finish would be hard to see). Shipping included within the USA (outside of USA contact us for quote) Pre-orders being accepted now. Lifetime replacement warranty, excluding anodize and hardware. To place an order, email us at: mayhem_eng@yahoo.com |
I want a set of comp live weight wheels to run as narrow of a track width as possible without any clearance issues......What do I need?
