06-18-2009, 12:36 PM | #1 |
Newbie Join Date: Jun 2009 Location: Chula Vista
| Axial chassis + Berg?
Will a chassis (dmg) designed for an Axial bolt right up with a Berg setup? Specifically will the link/shock mount points be in right spots and will the geometry be the same? Thanks!, Eric |
06-18-2009, 12:44 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Doubt it. The links are going to be different at the least.
06-18-2009, 01:07 PM | #3 |
RCC Addict Join Date: Apr 2009 Location: Anderson
Like RockCrawler said. It is more about the length of the links and not the chassis. I know our chassis can run both. It just takes different length links to make it happen.-Jason
06-18-2009, 01:16 PM | #4 |
Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
dont waste youy time trying to make it work. i did and it wsnt worth it. i have a build thread a few posts down, it is in there
06-18-2009, 02:09 PM | #5 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
I am using an mfm black widow with my berg axles. So far it has done great. I had to replace the revo rod ends with jato ends and shorten the shocks. After that it was dialed. |
06-19-2009, 09:08 AM | #6 |
Quarry Creeper Join Date: May 2006 Location: York Area
I was running a stock axial chassis with Berg's and nitro MT2 shocks at the last comp, Just had to make my own links. It was only to get me by until my Havoc chassis arrived but the truck worked very well. I won the comp with it |
06-19-2009, 09:30 AM | #7 |
[HOONIGAN] Join Date: Jan 2008 Location: Littleton
I think Jason was running berg axles with a axial chassis.... It seemed to be a very capable set-up. You might try using the search feature.
06-19-2009, 11:37 AM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
| yeah, me, Jason and Chris Little all have run the stock axial chassis on the berg in the past. I don't remember any major disadvantages to it, but I can imagine there are other chassis' that allow much better link geometry
06-19-2009, 11:39 AM | #9 |
Quarry Creeper Join Date: Sep 2007 Location: Looking for rock piles
i got a havoc and let me tell you it is a GREAT chassis you can run it high 3.25 or low it likes it all mine seems to work VERRYY well at 3.25 and the cust. service is GREAT youll like when you get it .
06-19-2009, 05:15 PM | #10 |
Glad to hear that, I got the chassis today and am gonna run 3" ground clearance, we tend to have alot of sidehill and off camber climbs at our comps and I don't want to loose any stability.
06-20-2009, 02:37 PM | #11 |
Thanks guys for the input. I may not go with a tube chassis. I hope someone comes out with a Berg specific tube chassis...
