06-23-2009, 02:22 PM | #1 |
Newbie Join Date: Jun 2009 Location: Chula Vista
| Body mounts?
Sorry but this may be a newbie question. I'm building a KK 4.0 Berg and was wondering what body mounts should I use. Or should I just use the stock body mounts that protrude from the sides? -Eric |
06-23-2009, 02:30 PM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
i have stock Axial mounts bolted to the chassis virtically on my 3.5
06-23-2009, 02:45 PM | #3 |
Pebble Pounder Join Date: Apr 2008 Location: Fort Wayne
I use some standard AE body mounts. On the back, it has a hole for the 4-40 screw and post. I dremel grind a small pocket below a shock mount hole for the post and screw through the backside of the chassis. The post keeps it from rotating. Has really worked awesome for me. The bottom pic is a Losi mount, but its the same concept (that probably costs a few bucks more). Check the pics....
06-23-2009, 02:46 PM | #4 |
06-24-2009, 01:45 PM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: Fargo
I like the wire clamp setup. First time I have used it and it works great. Just pit a piece of fuel tubing or servo tape around on of the chassis brace then run a bolt through the clamp into your favorite mount. Perfect! |
