06-26-2009, 04:02 PM | #1 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| 4s Lipo in my Berg
All I can say is WOW. I am running the D biscuit 45t handwounds and this thing screams. Mamba Max ESC and 4s is the way. If anyone was on the fence, leap off now.
06-26-2009, 04:20 PM | #2 |
ive considered it... i break enough shit with 3s though, it would only get worse with 4s.
06-26-2009, 05:46 PM | #3 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
06-26-2009, 07:23 PM | #4 |
Rock Crawler Join Date: Jul 2007 Location: central PA
My normal setup is a 2200mah 4S and 35t handwounds...its too much fun to go back to a weaker setup now. Although Ive been using 55ts temporarily since I cooked one of the handwounds. Ive seen times where I could use even more wheelspeed to get up really slick and steep faces. But thats just ridiculous for normal comp running |
06-28-2009, 09:06 PM | #5 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
So how are the berg parts holding up? I ran a 4 cell in my super but the clod gears didn't like it.I did finely get some a steel racing gears to work |
06-29-2009, 09:14 AM | #6 |
CD13 The only thing I have broken is dogbone pins. That isnt a problem when my steering is turned down though. I just like the 40-45* steering angle. I took an outer housing bearing the other night too. That is just from long-term use though...I've had this thing since early November. The gears look great still. I see no way of breaking gears unless a bearing goes out in the case itself and they bind themselves up |
06-30-2009, 08:37 AM | #7 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
I have been running mine on 4s since the beginning. (a little over a year now) never had a problem with it. 4s, Sidewinder and 55t, more wheel speed then I could ever need, and the slow speed control of 55t.
11-04-2009, 01:34 PM | #8 |
Quarry Creeper Join Date: May 2008 Location: So-Cal
I like the idea. How are your rigs holding up? Anybody else have coments on 3s or 4s?
11-05-2009, 10:43 AM | #9 |
Still running strong |
11-05-2009, 10:57 AM | #10 |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
I run a 4s in mine pretty often and in my AX-10 both with sidewinders and never had a problem.
11-05-2009, 01:24 PM | #11 |
I am still running 4s in my Berg. It eats the small 3rd gears if you shock load them, but I refuse to go back to 3s. On a side note, I have been running a Tekin FXR on 4s with no issues since worlds.
11-05-2009, 01:28 PM | #12 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I'm temped to try a 4S once I get my TorqueMaster ESC installed.. Does it feel a lot like the jump from 2S to 3S? 2S feels completely gutless to me after driving with 3S for so long...
11-05-2009, 07:36 PM | #13 |
I just like the snappiness of it...makes the 3s feel sluggish You can litterally hop over obstacles that were impossible before |
11-06-2009, 10:46 PM | #14 |
Newbie Join Date: Sep 2009 Location: 'Dego
How\where are you guys mounting these 2200mah batteries? All the 1500mah+ lipos I have seen are super long. For a crawler that is. Im running a Kamakazie Chassis for what its worth. |
11-26-2009, 02:44 PM | #15 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
So the general lot of you are running sidewinders? Where are you getting the 4s batteries from?
11-26-2009, 02:53 PM | #16 | |
Rock Crawler Join Date: May 2006 Location: Georgia
11-26-2009, 06:36 PM | #17 | |
Rock Stacker Join Date: Oct 2009 Location: Canada
Good to know the sidewinder can handle 4 cell. | |
