06-26-2009, 06:37 PM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
| HELP CKRC 120mm threaded shocks
i just got the 120mm shocks from CKRC racamened for the berg and they are vary nice shocks but the are really stiff. like if you push them down it takes like 1 min for the hole shock to come back to normal
06-26-2009, 10:06 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
what weight oil is in them?
06-27-2009, 12:05 AM | #3 |
06-27-2009, 12:32 AM | #4 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
| Your doing it wrong. dont use 5wt oil for other shocks. get RC shock oil. try this: http://www.tcscrawlers.com/Racers-Ed...l-p-16660.html |
06-27-2009, 07:57 AM | #5 |
why use a thicker oil when even a 5wt is to stiff mabe im wrong (most likly) but do you think 65 70 wt would work
06-27-2009, 08:48 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I don't know anything about those shocks but make sure the piston holes aren't plugged or drill them out for more action.
06-27-2009, 10:25 AM | #7 | |
RC shock oil and vehicle shock oils are WAY different. just head to a hobby shop or order some online and try it. and also make sure the holes in the pistons are open and clear of any blockage. | |
06-27-2009, 10:28 AM | #8 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
just get some rc shock oil, that will fix your problems.
06-29-2009, 10:27 AM | #9 |
sorry i was gone this weekend. but the thing is is that 2 of the shocks are stiff and slow but the other 2 have tha same oil in them and the are fine :?
06-29-2009, 10:32 AM | #10 |
Pebble Pounder Join Date: Mar 2007 Location: reno
mayb there to much oil in them
06-29-2009, 12:23 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Brown City, Mi.
One way or another your gunna have to tear those 2 shocks apart. When you take them apart, drain the oil, and then put the shock back together. If it frees up ,well its the oil or the oil holes in the disc, or the disc is to tight in the shock body, and is dragging. Hope that helps. Good luck... |
