07-01-2009, 12:43 PM | #1 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| Failed torsion Build/t
Rushed to finish it so I could run it up in vegas with the sin city group last weekend. Integy 45t's MM esc and ccbec 7955 steering 65hb dig(punk dig is in the mail ) rc4wd big offroader... Mayhem 7's, panthers kk zero t chassis Won some money the first day there and found a nib nomadio react for $200 so it replaced the rc4wd radio. on to the pictures Need to add spacers to the torsion arms and play with the links some. My first 2.2/berg build so any help/criticism is welcome |
07-01-2009, 01:24 PM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
got a pic of how the upper links are mounted at the axle? and how the torsion links are mounted at both ends? those would help
07-01-2009, 01:41 PM | #3 |
| Rear is the same except spacers are equal length and no bracket |
07-01-2009, 02:15 PM | #4 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Looks good man! and that was a freaking steal on that radio Ive wanted one of those for a while now. |
07-01-2009, 02:40 PM | #5 |
yeah i can't believe the deal he found on that radio. failedabortion told me that spektrum DSM receivers work with it, if thats true im buying one for sure.
07-01-2009, 02:44 PM | #6 |
07-01-2009, 02:47 PM | #7 |
yep the react is the only radio i'd replace my DX3 with. don't like the DX3R, 4PK is too expensive...
07-01-2009, 02:49 PM | #8 |
Im actually about to post my DX3 up forsale, I hate having to hold the 3rd channel button while in dig. Its caused me to hit too many gates Failedabortion, sorry about jacking your thread |
07-01-2009, 09:18 PM | #9 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
Liking the Custom OTA servo mount/setup there FailedAbortion- was your LF torsion link hitting the servo case? I made my 1st set of links from the 5/16 delrin and didn't like the clearance - so I cut the bent Berg uppers down so I didn't have to space them at the chassis. . so far so good + they match the Axles. Looks good 4sure, and congrats on the killer radio deal! |
07-01-2009, 09:28 PM | #10 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Nice. When I read the title I was expecting some kind of disaster of a build . Good deal on the React. I just picked one up used for $150. Its a great radio and Im in the market for another |
07-02-2009, 03:34 AM | #11 | |
| No problem, had the same conversation with dieselfuel while in vegas Quote:
07-02-2009, 03:48 AM | #12 | |
Just remembered to check that...Binds to a mrc receiver...Which is dsm. Not sure on the range with it though. | |
07-02-2009, 11:03 AM | #13 |
07-02-2009, 02:10 PM | #14 |
| Oh well, just picked up a Nomadio React TX from SVEN for 75 bucks Im going to bind it to my Speky sr3000 receiver. Cant wait, that radio is so badass. Last edited by Colby; 07-02-2009 at 02:12 PM. |
07-06-2009, 02:57 PM | #15 |
Changed some stuff around. Picked up some new lipo's yesterday( https://fusion-pack.com/productdetai...id=156&cat=113 ) and the punk dig( http://www.punkrc.com/index.php?main...7f5619ecdf7772 )showed up today. Crammed the dig, mm and receiver between the chassis plates and the Fusion 1300 3s pack fit between the lower and upper links. Broke the stock(modified) lockouts yesterday so had to cut some flat stock until someone has lockouts in stock??? The lipo looks tucked up there enough that it should be fine, will put a piece of lexan to cover it if it gets caught on something. |
07-06-2009, 04:34 PM | #16 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
Diggin' the build so far I usually keep a close eye on the Zero-T build's. That spot is money for mounting your lipo. Alot of guys around here go that route and it is working out well. I use a couple of velcro straps. Did you have the battery mounted on the chassis prior? What the big draw with the Nomadio? You and CTK had me searching ebay this weekend for a React. :? |
07-06-2009, 04:56 PM | #17 | |
The nomadio has 4 channels, cheaper than a 4pk or dx3R. The receivers seem hard to get ahold of but if you want only 3 channels you can bind it up to a spectrum dsm rx. Only down sides I see is the screen is harder to read in low light and the rechargeables suck. | |
07-12-2009, 09:59 PM | #18 |
Weighed it today after switching to rovers and the mayhem's, 5.5lbs rtc. Lost some articulation but like the lighter rig feeling, might try a sprung setup soon Still can't find any lockouts in stock anywhere???? |
07-12-2009, 11:06 PM | #19 |
How are you liking your punk dig switch? Ive had mine for a week and still havent been able to run my truck... Also, you should use the kamikaze dig tray and the electronics plate for the rear axle. That would clean your truck up big time |
07-13-2009, 12:47 AM | #20 |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
