07-01-2009, 01:50 PM | #1 |
Rock Crawler Join Date: Aug 2005 Location: Lufkin, Tx
| DNA snipers and CKRC high steer?
i just bought a new set of DNA snipers for my new build and come to find out they will not work with KK high clearance link or VP high steer arms. I could notch the VP arms to make them work but the screws will still hit the rod end. With the KK link the scews on the wheels hit the rod end as well. I was reading the CKRC info on there knuckles and it says the arm is moved further away from the wheel. Anyone running this combo? I want to make sure before I order another $35 set of knuckles that it will work. If not then I will have to order a new set of stock knuckles as mine are cut. |
07-01-2009, 02:48 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I run the Snipers and the KK Link with the stock knuckles... The Snipers did not fit on the CKRC's when I had those. I have my screws countersunk...less problems and better clearance on the side. |
07-01-2009, 03:02 PM | #3 |
Quarry Creeper Join Date: Dec 2005 Location: kerrville
I run snipers with the ckrc.....the trick is to either put washers to space them out a little bit or use a much wider hex like the ones they use to widen the MRC.
07-01-2009, 04:36 PM | #4 |
07-01-2009, 04:45 PM | #5 |
07-01-2009, 09:04 PM | #6 |
