Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: berg steering
Old 07-12-2009, 10:12 PM   #1
Default berg steering
OK,
so i am building a burg...
there i said it......
i got it to a roller in about 3- 4 hours where i think it will be a good start...
but no steering yet..
sooo.. what steering is everyone running and why????:?
i have not seen one yet that thrill's me...:?
thanx
pic's might post later...
roksloski is offline   Reply With Quote
Old 07-12-2009, 10:17 PM   #2
666
MODERHATER™
666's Avatar
Heres my homemade WBTA setup.
666 is offline   Reply With Quote
Old 07-12-2009, 10:25 PM   #3
hey 666
how is that on the servo...
looks like it would put unwanted strain on the servo...
it is out of the way...
Old 07-12-2009, 10:49 PM   #4
Didn't want to use the stock mount because the of the clamps hanging below the axle tube.
Failedabortion is offline   Reply With Quote
Old 07-12-2009, 10:56 PM   #5
I was thinking of using one stock clamp all the way over by the gear box and the threaded hole by the shock mount with a carbon fiber plate to mount the servo on...
still not sure yet....
thanx
keep the pictures comming........
Old 07-12-2009, 11:28 PM   #6
I've been happy with my ckrc tie rod so far. It's not pretty after I took the dremel to it but it works.
I like Yotachumps setup the best myself but I haven't driven it yet. Switching from my current toe-out to his toe-in setup will probably be a little weird to get used too when I get one though.
BigB_117 is offline   Reply With Quote
Old 07-12-2009, 11:36 PM   #7
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
thanx
That what I use
If you would like the 1:1 template to make your own then PM me with your email address.
Harley is offline   Reply With Quote
Old 07-12-2009, 11:51 PM   #8
Now thats very clean and simple
just not sure why the servo has to sit off center on one side???
thanx
anyway the servo horn can point down?????
only by raising it up maybe???
Old 07-13-2009, 09:57 AM   #9
Here is my steering set-up that gathered some attention at our last GTG. It os a modified CKRC setup with an adjustable extension to set toe, and a delrin guide plate to guide the tierod movement 100% of the throw. Works extremely well.
Pappy is offline   Reply With Quote
Old 07-13-2009, 10:33 AM   #10
i have seen those work, and they work pretty well..
the ones i have seen were a little floppy because they didnt have delrin plate like you do.. good idea
why the axial bent rod ends..???
i never had good luck with any axial rod end, the plastic is so soft i have stretched them out, then the ball is loose.....
Old 07-13-2009, 10:40 AM   #11
Crawler Design Works OTA/BTA........Love It !!!!
RC Shocker is offline   Reply With Quote
Old 07-13-2009, 11:48 AM   #12
Well to be honest, that is what CKRC called for in the build, and I have yet to find a metal replacement with a similar bend in it. It was close fitting the way I have it, and dimensions would need to be similar. Any ideas are welcome...I'm still very much a noob.
Old 07-13-2009, 11:49 AM   #13
Wow, is that a clean looking steering set-up!
Old 07-13-2009, 03:19 PM   #14
Default steering
Hey Mike i will have a ckrc steering available when my yotachump steering shows up! It has al the necessary mods to fit, just like big_117's
PEE WEE is offline   Reply With Quote
Old 07-13-2009, 03:33 PM   #15
mike.. save yourself a lot of time...CDW STEERING KIT
ROCKCAD is offline   Reply With Quote
Old 07-13-2009, 06:08 PM   #16
Sounds like you should design one that is so much better than everything else, since you think all the other designs out there suck.
The Violator is offline   Reply With Quote
Old 07-13-2009, 08:53 PM   #17
thanx for getting me one of the CDW 's.....
yea...
the more i look, the more yodachump's looks the easiest....
we shall see....
trucknuts..
Old 07-17-2009, 11:02 PM   #18
Default Order
How did you order the yotachump steering?
jadogscamaro is offline   Reply With Quote
Old 07-17-2009, 11:25 PM   #19
http://www.rccrawler.com/forum/showthread.php?t=184685
