07-14-2009, 12:28 PM | #1 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| roksloski's burg
well thought i would give one of these a try... nothing special... all traxxas links and rod ends.. Hellbentrodder chassis... thanx hellbent.... losi shocks... fubar lockouts..hope to swap these out for jeepindoug ones... VP knuckles ax stub axles will have a tekin FXR.. CC bec punckrc dig switch axles clocked 20deg. steering not quite sure yet motors...???? JR8711 to get to turn.. yea it is a little wide Eritex wheels.. AX offset for now A special thanx to Jake at Jake's performance Hobbies... just realized i didnt spell my name right in the heading...DOH...... Last edited by roksloski; 07-14-2009 at 09:04 PM. |
07-14-2009, 12:37 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Lookin good Mike These MOA things are kind of dated now, you should have gotten the LCC. Check out my Skeeter thread for my current cost effective wheel solution. |
07-14-2009, 12:38 PM | #3 |
Hateraide Join Date: Dec 2008 Location: Mission BC
Loks good def get some berg offset rims tho |
07-14-2009, 12:45 PM | #4 | |
i run my truck 100 times more than anybody i know and didnt think the LCC would hold up to 3-4 hours, 3-4 days a week of non-stop crawlin. . Last edited by roksloski; 07-14-2009 at 12:47 PM. | |
07-14-2009, 10:11 PM | #5 |
RCC Addict Join Date: Mar 2008 Location: SSF
It looks the same as when I seen it saturday..........get to work Mike. I'll bet that within the first hour of driving it you'll say........"why didn't I build one earlier?" |
07-15-2009, 04:24 PM | #6 |
Well today i decided that my chassis was a little wide (2 7/8 outside to outside) so i took 3/8 off the skid plate, now is 2 1/2 wide... not sure that will matter any... had a set of wheels that i got with my axles that are burg offset but didnt have any lok rings,, so i took them off my Mayhem axial wheels and mounted up a set of tires, now its at about 10 1/8 wide instead of 11 1/8 wide... looks ok now Tires seem to rub the shock spring at full turn and pull the spring off the cup.. does anyelse have this problem?????? more pic's to follow later Last edited by roksloski; 07-15-2009 at 10:26 PM. |
07-15-2009, 04:28 PM | #7 |
Can you get your shocks upside down? Easier to refill also. |
07-15-2009, 04:38 PM | #8 |
07-15-2009, 05:01 PM | #9 |
| Probably true on race cars/trucks but I honestly don't think it matters on crawlers. I care more about the rebound performance than the compression.
07-15-2009, 09:40 PM | #10 |
Rock Crawler Join Date: Jun 2008 Location: dublin
07-15-2009, 09:42 PM | #11 |
p.s..... roksloski and berg |
07-15-2009, 09:47 PM | #12 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
p.s you need steering |
07-15-2009, 10:14 PM | #13 |
07-15-2009, 11:21 PM | #14 |
Air bubbles are always at the top, that's just physics, no matter which way you run the shocks. With the cap up at the top is really easy to refill when it's necessary. I've been told the green slime really helps the cartridges but no first hand myself. |
07-15-2009, 11:41 PM | #15 |
07-16-2009, 05:05 PM | #16 |
a few new pic's burg offset wheels narrowed the chassis 3/8" in. its 2 1/2" wide now still waiting for a few more parts.. |
07-17-2009, 10:47 AM | #17 |
Newbie Join Date: Mar 2008 Location: Sonoma
Whoa i cant believe it!
07-17-2009, 03:27 PM | #18 |
Rock Crawler Join Date: Apr 2009 Location: Sonoma County
07-17-2009, 04:03 PM | #19 |
And DIG SWITCH...... |
07-23-2009, 03:41 PM | #20 |
a couple of tease pictures... finally got my punk RC dig switch. pulled out the 8711 servo out of my SWX for my steering now i just need some sort of steering system (yotachumps most likely) and no those are not the tires i will be using.. |
