07-15-2009, 04:14 AM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
| Axle problems binding
I got my berg back together last night.I put vp knuckles axail stubs and cdw steering now a random times the axle will bind up i took it apart 4 or 5 time and cant find anything wrong no metal shaving nothing wore could it be a bearning? anyone else had a problem like this ?
07-15-2009, 07:29 AM | #2 |
Rock Crawler Join Date: Jul 2007 Location: central PA
I had the same problem and thought it was the axles but it ended up being my tie-rod ball ends hitting the beadlock screws on my DNA wheels. Just a thought
07-15-2009, 08:13 AM | #3 |
i have mayham wheels and they very close but no rubin that i see
07-15-2009, 10:16 AM | #4 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
What kind of binding?
07-15-2009, 11:29 AM | #5 |
as the front axle turns it pops and binds btw im like-n the chassis and steering MR.CHUMP |
07-15-2009, 11:38 AM | #6 |
07-15-2009, 12:06 PM | #7 |
ok thanks ill check soon as get home i think it is outers somewhere |
07-15-2009, 12:31 PM | #8 |
Hateraide Join Date: Dec 2008 Location: Mission BC
have you tried backing off the nut that holds your tires on, just back em off some because sometimes they arnt perfect ive had to do that and just loctighted them and it worked fine
07-15-2009, 01:34 PM | #9 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
When my bergs bound it ended up being the inner bearing. It came apart and one little ball bearing got stuck between the 3rd and 4th gear. Made ma loose to a scaler!!!
07-15-2009, 06:19 PM | #10 |
What hexes? I tried some that allowed the back of the wheel at the hex rub the axle housing. Also, if you used 2 o-rings in the cup, it will seem like it binds while turning until the inner one seats.
07-15-2009, 06:29 PM | #11 |
axail hexes and i used one o ring the only thing i can find is that it might be binding because of the inner axle shaft and stub are very tight the more i run it the better it is getting
07-18-2009, 04:44 PM | #12 |
Quarry Creeper Join Date: Feb 2008 Location: mt sterling
