12-11-2009, 11:09 PM | #1 |
Pebble Pounder Join Date: Jul 2009 Location: TEDS GARAGE ,PM HOBBY
| dog bones
I keep breakin the front dog bones shering the pins off new axles with 35 turn twister ckrc motors is it my driving or have I missed something so that four in less then an hour 2 short 3 long
12-11-2009, 11:16 PM | #2 | |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Are you digging at full lock? Take your EPAs down a bit or buy CVDs and call it a day. What some people do also is put a different pin in which seems to help. Last edited by treday619; 12-11-2009 at 11:19 PM. | |
12-12-2009, 07:17 AM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Put an O-ring on the axle (against the housing bearing) to keep the pin in the slot and turn down your epas so the stub isn't hitting the axle at lock.
12-12-2009, 07:38 AM | #4 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
Buy a set of CVD's from SDS and be done with it. The only other option is to turn down your EPA's and keep fresh Outer Stubs in it .The more wear in the stub the further the pin comes out and the more slop you get.When that happens the pin can not take the sudden slap it gets when bouncing or turning while in and out on the throttle. |
12-12-2009, 08:13 AM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
Make sure you do have the o ring in the stub axle as well. Seems like you may be having the axle slide out to far and binding up. 2 o rings for stock stubs, 1 o ring for axial stubs. |
12-12-2009, 09:37 AM | #6 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
also lay off on the throttle little. you need to learn to use it when you need it. when i swicth to 35s i broke lots of axles and small thirds. but now have cvds. |
12-12-2009, 10:53 AM | #7 |
cvds from sds have nt seen them where can I order them from or what cvd is the best to use
12-12-2009, 10:55 AM | #8 |
Rock Crawler Join Date: Jan 2007 Location: Midway
35 turns spell disaster. With that much speed and torque, the weakest link in the power train has to fail. Like others have said, laying off the fast trigger finger helps. |
12-12-2009, 11:31 AM | #9 | |
TCS has them: http://www.tcscrawlers.com/Super-300...s-p-17923.html 300s are the best CVDs you can get. If they are too expensive then your only other option is RC4WD. You just have to wait until they have them in stock..... | |
12-12-2009, 03:02 PM | #10 |
thanks Ill order some and be easier on the finger
12-12-2009, 03:48 PM | #11 |
Rock Stacker Join Date: Feb 2009 Location: portland
no need to be easier on the finger with super 300s dave dose NICE work |
12-13-2009, 02:34 PM | #12 |
Quarry Creeper Join Date: Sep 2007 Location: Looking for rock piles
i had the same prob w/mine till i laid off the trigger now i haven't broke one for a while (jinks)i will now anyway try that and see what happens .
