05-28-2010, 08:28 PM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| LOWBOY v3 BERG BUILT.
Got the juice baby! the Y-town bjuice v3. chassis listing http://www.rccrawler.com/forum/showthread.php?t=221702 specs.. chassis.. v3 lowboy chassis/skid berg clocked axles front/rear *wheelbase 12 1/4 track width 11* hr hiclearence knuckles for ax-10 (threw'em on just to see) ckrc rear lockouts i think its 86 jeeps steering kit?? revo rod ends delrin links uppers - 4 5/8frnt/5in rear kk lower delrin links -5in losi shocks w gold springs in frnt/whitesprings in rear feels like 45wt -50wt oil elec... 45t epic motors (not sure on pinions) mamba max esc punk dig v2 cc bec bowtie fat batt plate hitec 5955 servo (got a HV on the way!) 3c lipo 1300mah 25c Dx3r/spek rec *i found that if you set your brakes(-brakes) on the c button, you can fade the rear in or out* didnt know if anyone knew that or not. wheels/tires.. i have some vp slws coming in.. vp foam kit hotbodies sedonas/? hotbodies rovers/cac tuckers "freakin awesome looking" panther leopards/motorwork 7 pitbulls/? and the dna/rovers it came with.. i think im set on wheels and tires!! lol i had traded my slash 4x4 for a berg for disney wknd...blah blah it had a kamikaze chassis on it,...i liked it.. but i didnt really wanna run a body.. then i saw this lil dude!! i watched a couple at disney that were awesome! so when i promplty got back to a computer,i placed my order. and it got here today!! and already assembled and ready to rock!! cut up one of my old bodies for the panels. just the hood and roof. Last edited by ROLANDROCKSHOP; 05-29-2010 at 05:58 AM. |
05-28-2010, 08:48 PM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
And then..................................
05-29-2010, 05:55 AM | #3 |
pics uploaded! |
05-29-2010, 06:53 AM | #4 |
Relaxed ! Join Date: Apr 2009 Location: On the road again !
05-29-2010, 07:42 PM | #5 |
thanks guys! i was told to run golds upfront on bergs?? so whats the real story?? anyone?? |
05-29-2010, 07:50 PM | #6 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
05-29-2010, 08:03 PM | #7 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
X2 Later, Farmer |
05-30-2010, 09:39 AM | #8 |
thanks guys!
05-30-2010, 10:18 AM | #9 |
I went back and looked thru your pic's again. Alot of guys will also mount the shocks more "inboard" on the chassis. You can see it in several other build threads. You can experiment with it though. Why do you have the battery on the rear axle when running the newly-designed skidplate? |
05-30-2010, 11:26 AM | #10 | |
Quarry Creeper Join Date: Feb 2009 Location: ewetah
What do you mean by the shocks being more inboard; laid down more, or closer to the chassis? I was wondering the same thing about the battery as well. | |
05-30-2010, 12:23 PM | #11 |
it was that way,when it came in the trade. ill get on it boss!! |
05-30-2010, 12:35 PM | #12 |
05-30-2010, 04:29 PM | #13 |
05-30-2010, 06:32 PM | #14 |
*redid the front shock upper mounts...moved back to 4 hole from front. moved my batt up onto the tray skid,removed the rear plate.* ? i see some guys with there shocks up side down?? does it really make that much difference or do the shocks react differently?? and just how long do my motor wires need to be?? i think the dude who solder it put about 2in to much on both ends?! and sometimes my rear motor wont kick in until im @ 50% throttle?? the green light is on the pk dig,batt's got plenty of juice,epa's over 70.?? or is that the famous clod stall.. thanks gents youve been very helpful. punk dig kicks as! the vp slw's /Hb sedonas(+2oz frnt) (0 rear) gripped very well. stock foams in the rear,vp foam mix up front. |
05-30-2010, 07:36 PM | #15 |
About the rear motor not kicking on until half throttle... That is stall but it sounds like you have something increasing the effects. Check for this stuff... Gear mesh too tight in rear. Wheel in back on too tight causing binding. Bad motor. Not sure which rear lockouts you use but make sure one isn't rubbing the stub axle inside. A buddy of mine got some blitz motors on my reccommendation. One was doing exactly what yours was. He knew it was the motor because he switched them rear to front and it did the same thing up there. Fantom took care of him though. With no binding on level ground, your motors should start up at the same time with throttle input. |
05-30-2010, 08:53 PM | #16 |
ok they do start up on flat ground equally. its only on a vertical climb that it becomes a problem.. about the 3 try it just gets worse and worse until i blip it really good.. i will check the lockouts "ckrc".. thanks man! |
05-30-2010, 08:58 PM | #17 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
What the hell is going on here....Josh has a 2.2 comp rig..... Looks good brotatoe....Get me some lengths and we'll get some carboms on that sucker.. |
05-31-2010, 06:33 AM | #18 | ||
thats eye to eye revo ends. the v3 juicer weighs in at 5lbs 10 oz. thats rtc. checked the lockouts-no binding there.. motors comm shaft look good- brushes were a lil sticky, put a dob of oil on them.. checking gear mesh next.. | ||
05-31-2010, 08:03 AM | #19 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Some good info nice looking rig
05-31-2010, 08:17 AM | #20 |
Lookin nice. Better get ready for this weekend with that rig!
