07-03-2010, 06:35 PM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: italy
| setting of TEKIN FXR
I just got my 2 TEKIN FXR and now need some HELP for the setting part..... Any1 can tell me how to set the different part of the ESC .... (reverse, drag brake ecc)? |
07-03-2010, 10:38 PM | #2 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Easiest way get a tekin hot wire. That how I did mine straight foward and simple.
07-03-2010, 11:10 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
just take a few min.s and read thies... http://www.teamtekin.com/manuals/FXManual.pdf Super easy to set up. No need for a hotwire unless you want to change your throttle profile (the only thing you cannot control directly on the unit itself) but you shouldn't need to mess with that. Last edited by TANK; 07-03-2010 at 11:26 PM. |
07-03-2010, 11:13 PM | #4 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
The link posted above seem not to be working for me... Try this link and read the "Quick Tune" directions for setting up your fxr... http://www.teamtekin.com/manuals/FXManual.pdf It's what I did with mine. |
07-04-2010, 01:02 AM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
It is very easy to set up using the mode and incr buttons (No hotwire needed). Here are the basic crawler setting I use. DRAG BRAKE = 11 REVERSE STRENGTH = 11 CURRENT LIMITER = 11 PUSH CONTROL / ANTI DRAG = none REVERSE TYPE = 2 THROTTLE PROFILES = 3 VOLTAGE CUTOFF = 3 (for 3s lipo) |
07-04-2010, 01:39 AM | #6 | |
Pebble Pounder Join Date: May 2009 Location: Scotland
I assume throttle profile 3 is the default setting on the Fx-R which is Linear and according to the instruction sheet , non adjustable . Can this be adjusted via a HotWire OldHippie ? Apologies if this has been asked before . | |
07-04-2010, 06:35 AM | #7 | |
Really tnx for this 1, i just finished to set and made the same exept for the current limiter because i don't know what it is | |
07-04-2010, 10:01 AM | #8 | |
I haven't used my hotwire on an fxr for long I don't remember but I think ya can? Since I have a 4pk with throttle expo I don't deal with the curve on the esc. Sorry I'm no help. | |
07-04-2010, 10:03 AM | #9 |
07-04-2010, 11:56 AM | #10 | |
