11-04-2010, 06:07 PM | #1 |
Newbie Join Date: Sep 2010 Location: Toronto
| clocking CKRC Low Profile Berg Axle Tubes I received these in the mail today, very nice by the way, and have a few questions that I hope somebody can help me out with. My questions pertains to clocking and caster of these axles. I'm going to try going with about 20* in the front. The problem i'm having is I don't know where 20* is and how to find it or for any * angle for that matter. All I know is clocking these tubes is achieved by turning the tubes to the * angle that you want and locking it in place with 3 grub screws that are located at the end where the flange assembly attaches to the gear box. Also if I wanted, is it posible to add caster, and how would I go about doing so. Thanks in advance, Radical RC. |
11-04-2010, 06:14 PM | #2 |
Edit: clock it 20 degs and then use shorter upper links for some positive camber.. ... Last edited by Szczerba; 11-04-2010 at 08:31 PM. |
11-04-2010, 06:21 PM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The tubes can rotate in the flanges, so you won't need a tool. I'd say put the axle together and leave the tubes loose in the flanges, then adjust to your liking, when your happy with the angle, make it permanent.
11-04-2010, 06:25 PM | #4 |
| opps.. forgot about that feature on these. Ignore my first post.
11-04-2010, 06:28 PM | #5 | |
11-04-2010, 06:33 PM | #6 |
I don't know the exact measurement, but the distance between holes on my clocked front is about 4.5mm- that is pretty rough though, maybe JeepinDoug can get you a more accurate number.
11-04-2010, 06:33 PM | #7 |
11-04-2010, 06:35 PM | #8 |
11-04-2010, 06:43 PM | #9 |
| Yep, of course you have to remember that my measurement is taken near the middle of the flange wall. Your measurement would be at the tube/flange meeting point, or junction, which would result in a smaller distance because it's closer to the centerline of the axle. I know there is some mathematical equation for it, but I sure ain't going to figure it out. Last edited by gunnar; 11-04-2010 at 06:46 PM. |
11-04-2010, 06:47 PM | #10 | |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
http://www.harborfreight.com/dial-ga...der-34214.html | |
11-04-2010, 08:09 PM | #11 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
ODxPI then divide by 360...or divide by 36 to get 10* distances
11-04-2010, 08:30 PM | #12 |
Pebble Pounder Join Date: Mar 2007 Location: reno
Here's Instructions show 15 degrees give you something. To start with http://www.ckrccrawlers.com/info-ckr...it-p-3072.html |
11-05-2010, 03:31 PM | #13 |
Thanks for the help. I'm looking into something right now. I will get back if I find that it will work.
11-05-2010, 06:13 PM | #14 |
Rock Crawler Join Date: Nov 2009 Location: Etowah
I used a straight edge on the back side of the inner c's with an angle finder on the straight edge. I have the tires mounted and setting at ride height . Hope this helps |
11-06-2010, 06:49 PM | #15 |
| This is what I was thinking of doing. Picked up an angle finder today. This should do exactly what I need it to do. Thanks greencrawler.
