12-06-2010, 12:00 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Team Red Eye
Well.. I couldn't beat them, so I joined them. Here is a roller from NicklePimp that looks situated so I don't want to change much. Maybe delrin front links, stainless/ titanium chassis hardware, and shocks/ springs setup closer to my old stuff. Steering setup made by Etype_R and I have zero plans of changing it. Axle wraps made by Lonewolf. We have a long winter ahead so this won't be a quick build. Right now I'm thinking 3s 40t's, dx3r + mmp with punk but I'm leaning towards micro pro's and a 3pk. I'm used to a 9.1" rear track width. Is there any wheel available that puts me close to that? Last edited by djjiz; 12-07-2010 at 04:44 PM. |
12-06-2010, 12:12 PM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
so purty in white - i rather like it more then the black -
12-06-2010, 12:24 PM | #3 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Maybe try some VP narrow tracks for the rear. What is the wheelbase, it looks kind of short. |
12-06-2010, 01:09 PM | #4 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
now that is some real beefy upper links ..... made me look twice rockshow has this old school mystique going on ... rig looks great |
12-06-2010, 01:55 PM | #5 |
Wheelbase is spot on.. I think it looks tall with the combination of over stuffed tires and springs maxing the suspension out. I'll change these seeing as the wheels were on my Losi and I have softer springs I'm going to try, including in the shock. Strawb.. I'm in Minnesota.. We're a little behind on everything. |
12-06-2010, 03:35 PM | #6 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Looks good If my eye's are right it looks like you have 350 hubs all round, is that correct? If so you could switch to 225's in the back and that brings in the track 1/4". That may be a start? Other than VP Narrow Track SLWs, which are no longer made, I'm not sure what else would get it any narrower. With 225 hubs the hex is almost at the face of the wheel. Kieren |
12-06-2010, 05:07 PM | #7 |
Good eye Kieren.. I only have two rims at the moment and both with 350's. I'll have to try the 225's and grind the hex a little. Shouldn't be too bad to get used to.
12-06-2010, 06:43 PM | #8 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
just deal with it.... Aint skinny no more Where are your other 2 wheels? |
12-06-2010, 07:02 PM | #9 |
It's not the size of the axle, it's how you use them haha. Your right tho bud.. These are far from what I'm used to.. Including this kick ass 3mm hardware. I have two delrin UCW's and they are losi offset so I might mount them up for now. I can't run it for another couple months and I'm excited about working on a new rig. |
03-08-2011, 08:40 AM | #10 |
No pictures yet but it's coming along nicely. T1E with modded skid and shock mounts cleaned up DH's with narrow hex SLW's with 250's KK front lowers t1e rear lowers Hard coated uppers with bent Axial rod ends Majority of hardware is stainless JPH 37 turns Dig switches 16-18g wire MMP un-cased and might try without heatsinc 86Jeep steering mod in progress 30* clocked front link clocked rear Trying siped pink rovers for spring but running Sedona fronts and Rovers rears when the rock temps get up. My favorite tool so far has been MAP gas. Loctite was pita for some reason. I'm at a spot on my steering mod that has me confused.. How are you getting your pinion to mesh? I've seen holes drilled in the case but nothing really clear as to where I would start. **Edit.. I'm kinda seeing where I should drill. Motors aren't in hand so I'm gonna wait for those before I commit to the holes. This has been a rewarding mod for me. I missed that. Last edited by djjiz; 03-08-2011 at 07:42 PM. |
03-15-2011, 02:38 PM | #11 |
| 86Jeep mod is about 90% done and a dremel did all I needed. Fun mod to do but I'm glad it's almost over with. New lockers are in the near future. The slop reminds me too much of my last rig. |
03-15-2011, 11:14 PM | #12 |
Roller status.. Steering is done enough for now. Last edited by djjiz; 03-17-2011 at 03:15 PM. |
03-19-2011, 05:48 PM | #13 |
The 10lbs of shit into a 5lb diaper starts. I should be able to drive this thing soon. Any tricks for fitting a Mamba Max Pro? I'm ready to make the skid wider but if I can avoid that that would be cool. And just to see if you're paying attention could you name this gun? Thanks. |
03-21-2011, 07:41 AM | #14 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
I think the name of that gun is "The Bad Ass Mother" |
03-21-2011, 08:13 AM | #15 |
RCC Addict Join Date: Jan 2010 Location: Dallas
How bout the Pink Pearl (the name of those goofy "erasers" we all had in elementary school).
03-23-2011, 07:41 PM | #16 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
That gun is "the noisy cricket"
03-23-2011, 09:09 PM | #17 |
Thought I was in a hurry to finish this but the weather says differently. I should have took more time on things.. Oh well. It's only short wire now and I'm learning to solder. Finally. I've been searching even under noisy cricket and still no results. I dont think a person needs to own something like that but it would be cool to find out what it takes.. |
03-23-2011, 09:25 PM | #18 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
U done yet???
03-23-2011, 09:48 PM | #19 |
03-23-2011, 10:36 PM | #20 |
