02-06-2012, 03:27 PM | #521 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Dlux Berg Build
over 2 years on the same gear and hex pins........... not one problem to date.......... just saying....................... |
02-06-2012, 03:40 PM | #522 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
| Re: Dlux Berg Build |
02-06-2012, 04:05 PM | #523 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
02-07-2012, 09:49 PM | #524 |
| Re: Dlux Berg Build
I got the shafts done last night. Not quite what I envisioned but they turned out great. Made from hardened 4140. They are 8mm at the bearing end and then from the bearing to the locker they are 7mm, gun drilled to 5mm all the way. No c-clips. At first I made them 8mm all the way across but once you hold 8mm in your hands, there is no question it is too much, plus, I wanted to get these at a reasonable weight so, I turned the portion from the bearing to the locker down to 7mm. I kept the bearing side at 8mm so the RC4wd hexes will fit. I still think that they are a bit too strong but I like that. In fact, I think they are so strong I am not sure testing would really be in order. I have a comp this weekend so I am going to run them for the next couple days and then on the weekend. After that, I have another idea for some serious weight savings. Here are a couple pictures showing the sizes. Stock, CKRC 6mm and mine. If you look closely, you can see the long 6mm shaft is bent the entire length of the shaft and on the short side you can see its bent at the threads. For the first time, its really, really nice to watch my tires run true, well, as true as the tire and foam allow. LOL. No more bending shafts, threads or broken hex pins for this guy. If you look at the part that goes into the locker you can really see the size difference. |
02-07-2012, 09:49 PM | #525 |
| Re: Dlux Berg Build
For being such a large shaft the weights came in really well. Just 1g per axle more than a 6mm shaft. |
02-07-2012, 09:55 PM | #526 |
| Re: Dlux Berg Build
I have been working at reducing weight on my car. Before I never put much effort into the wheels and tires as I didnt really care too much. I am going to try and take it further now and see how I like it. I still need to decide if I want to reduce weight with a smaller battery. My 800mah 40c have never let me down where as my other 450 and 350 have. I just dont know if its worth the 1oz loss. I also figured out that I dont like to change in situations between bigger and smaller batteries. It just changes the cars handling too much. I replaced all my screws in my wheels with AL screws. Pretty big difference. Should lose about .4-.5oz with just a screw change PER wheel. Almost 2oz for the entire car. I got my Sedonas down to 5.4oz for the T/W/F combo. Not too bad for those piggies. And for reference here is my unshaven Sedona on a 1.9oz wheel. |
02-07-2012, 10:50 PM | #527 |
| Re: Dlux Berg Build
Those rear shafts are beefcake for sure. Looks like you designed them for the superbully hexes also right? I'm sure anything is better than what you had in there before! |
02-08-2012, 12:18 AM | #528 |
| Re: Dlux Berg Build
Yep, bully hexes. They are not specific to the super though. Just 12mm.
02-08-2012, 12:27 AM | #529 |
| Re: Dlux Berg Build
Also forgot to mention that I switched up the wheel width in the front to .5 and am really liking them so far. I would not have even tried it but Marc from chaotic switched over to them and liked them. I may even check out .4's |
02-08-2012, 05:06 AM | #530 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
| Re: Dlux Berg Build
I noticed you had ran narrowed Sedona's in the past. What made you switch back? And what width foams did you run in them?
02-08-2012, 06:58 AM | #531 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
| Re: Dlux Berg Build
Beefy shaft, puny bearing. Have you thought of making larger bearing carriers?
02-08-2012, 10:23 AM | #532 | |
| Re: Dlux Berg Build Quote:
I ran Rover foam in them. I thought they may have been a touch stiff for my taste, pretty close though. | |
02-08-2012, 10:27 AM | #533 | |
I have been running the bearings in my super for a good amount of time. Obviously there is a lot more stress with those 8" tires than with 2.2's Sedonas. Time will tell and I will address it if its an issue. It would be easy on my axles to just double the bearing up. I wouldnt want to make the lockout any bigger. | |
02-08-2012, 10:49 AM | #534 |
| Re: Dlux Berg Build
The shafts look great Erik. Another fine part by dlux. Can't wait to get mine.
02-08-2012, 11:28 AM | #535 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
| Re: Dlux Berg Build
I had tons and tons of time on my v6/super bully shafts and never had one fail...I would not worry too much about those bearings.....
02-08-2012, 11:44 AM | #536 | |
02-08-2012, 12:06 PM | #537 | |
Quarry Creeper Join Date: Sep 2009 Location: Granite City (Mt. Airy)
I also changed over to Avid bearings back in May of last year; with no problems yet. | |
02-08-2012, 01:11 PM | #538 |
| Re: Dlux Berg Build
Great work Erik, Wish I would not have gone to an XR10 just so I could keep buying your Berg parts !!!!!!
02-08-2012, 04:34 PM | #539 |
Pebble Pounder Join Date: Feb 2008 Location: 801rcc
| Re: Dlux Berg Build
I think ya need to groove those pigs! Mine with .7's and an 850 hub come in at 5.1oz each! Thats with all steel hardware too.
02-08-2012, 11:27 PM | #540 | |
Crazy. That makes it tempting to groove them but I am pretty sure I came to the conclusion that I like them non grooved. | |
